schlauchdruide Guest
26-01-2014, 19:04 Subject: Engine Swap: Is It Possible? |
The original engine is a 2.0L TDI with engine code BPW, from an Audi A4, manufactured in 2006.
The engine to be installed is a 2.0L TDI with engine code BMN, from a VW Passat manufactured in 2006.
My question:
Audi crankshaft position sensor (CKP) located in the engine block, sensor wheel on the crankshaft.
Passat OT sensor on the front cover, clutch side; sensor disc inside the front cover.
Can the OT (output torque) signal from the BMN motor be processed in the Audi?
Thank you in advance for your help.
Translated on 06-10-2026, 19:44.
mullemaus Guest
26-01-2014, 20:44 Subject: Engine Swap: Is It Possible? |
It is processed by the engine control unit. You need to install this (in addition to the engine wiring harness), and then it will work.
Translated on 06-10-2026, 19:45.
26-01-2014, 21:31 Subject: Engine Swap: Is It Possible? |
Thank you for the response.
But that's exactly what I wanted to avoid.
The BPW Audimotor receives two signals per kilowatt revolution (two tooth gaps offset by 180 degrees on the encoder disc).
I have no idea about the BMN Passat engine.
Translated on 06-10-2026, 19:46.
mullemaus Guest
26-01-2014, 21:37 Subject: Engine Swap: Is It Possible? |
Thank you for the answer.
Regarding the BMN Passat engine, I have no idea.
You don't need any special knowledge. Just install the wiring harness and control unit that are compatible with the engine, and everything will work  .
Translated on 06-10-2026, 19:47.
26-01-2014, 21:50 Subject: Engine Swap: Is It Possible? |
Okay, then I will do it that way.
Thank you again.
chriskross Blaumann
Joined: 04/19/2006 Posts: 304 Karma: +3 / -0 Location: Österreich
27-01-2014, 7:26 Subject: Engine Swap: Is It Possible? |
If you modify the engine control unit (ECU), you will likely encounter problems with the immobilizer system, and the programming process will not work.
A6 AFB
A6 BRE DPF
Translated on 06-10-2026, 19:48.
27-01-2014, 10:25 Subject: Engine Swap: Is It Possible? |
I think I'm going to sit down again and carefully consider whether it wouldn't be more sensible to have the engine repaired.
klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
27-01-2014, 13:45 Subject: Engine Swap: Is It Possible? |
Audi/VW will certainly adjust that for you at a very affordable price  .
Profile PM Garage |
chriskross Blaumann
27-01-2014, 20:18 Subject: Engine Swap: Is It Possible? |
klahaui wrote: | Audi/VW will certainly adjust that for you at a very cost-effective price  | .
I don't think they can do that.
The only option is to turn off the WFS (Immo OFF)  , and then it should work. However, it needs to be tested to see how compatible the other control units are, such as the gateway, combination instrument, ABS, and ESP. You would also need to check the CAN BUS IDs, etc.
A6 AFB
A6 BRE DPF
Translated on 06-10-2026, 19:49.
27-01-2014, 21:20 Subject: Engine Swap: Is It Possible? |
Certainly, Audi can use the tester to reprogram the immobilizer  .
Profile PM Garage |
mullemaus Guest
27-01-2014, 23:27 Subject: Engine Swap: Is It Possible? |
Yes, Audi can use the tester to reprogram the immobilizer  .
Since there are different performance levels, I wouldn't generalize it like that.
Translated on 06-10-2026, 19:50.
