Piston Animation: ARL - Your Opinion Needed
Deus Violentia
Post17-02-2014, 21:09    Subject: Piston Animation: ARL - Your Opinion Needed Quote
After a long absence, I have a question for you:
Attached you will find pictures of an ARL piston with approximately 170,000 km on it.
from an engine with significantly enlarged piston dome features, which is also evident from the piston itself.
What I see: Partial adhesion on the top surface, and slight scratches that are only visible upon close inspection.
In my opinion, the piston skirt coating is likely caused by an extremely high fuel injection rate.
with the oil film washed away. Overheating of the omega cavity (see the burn mark above the).
(Bolt holes) No cracks found!
The engine was still running, but it had a crack in the cylinder head and was completely replaced with an automatic transmission, which is why it was ultimately discarded.
The engine block, including the crankshaft mechanism, remains. The connecting rods and crankshaft are in perfect condition!
Now my question: Assuming the piston still meets the dimensional specifications, is it still scrap metal?
Can I reuse it with new piston rings? What do you think about that?
 File size:  163.65 KB
 Viewed:  1604 times
 File size:  130.31 KB
 Viewed:  1587 times
 File size:  144.38 KB
 Viewed:  2031 times
 File size:  151.06 KB
 Viewed:  1830 times
 File size:  206.21 KB
 Viewed:  1968 times
BKD GRF
AHF EBF
Translated on 11-10-2026, 13:10.
Post17-02-2014, 21:22    Subject: Piston Animation: ARL - Get Expert Opinion Quote
Deus Violentia wrote:
...can I reuse it with new piston rings? What do you think about that?
It depends on what it's for and for how long.
I'd say he's definitely done for, as far as any future prospects are concerned.
Translated on 11-10-2026, 13:12.
Deus Violentia
Post17-02-2014, 21:26    Subject: Piston Animation: ARL - Your Opinion Needed Quote
Well, I was already planning to use that sentence in the relevant performance level, but I have my doubts about whether that would be a good idea...
BKD GRF
AHF EBF
Post17-02-2014, 22:19    Subject: Piston Animation: ARL - Your Opinion Needed Quote
Well, I wanted to use the sentence in the relevant performance class, but I have my nagging doubts about whether that would be a good idea....
Practice makes perfect icon_wink.gif.
Ich persönlich würde ihn ersetzen, weil der ET Aufwand in keinem Verhältnis zur evt. NaIt's a matter of personal preference.
If he or a replacement engine were to be operated in the same engine block again, I would check the block for flatness and, if necessary, have it resurfaced.
Translated on 11-10-2026, 13:13.
Deus Violentia
Post18-02-2014, 9:18    Subject: Piston Animation: ARL - Your Opinion Needed Quote
Thanks BM! In your opinion, which is more "critical"? The condition of the graphite coating, or the thermal overload that has already occurred on the material?
BKD GRF
AHF EBF
Post18-02-2014, 10:51    Subject: Piston Animation: ARL - Your Opinion Needed Quote
These grooves in the graphite coating often occur when the pistons are removed, due to deposits forming in the top of the cylinder above the first compression ring.
I would be more concerned about the thermal stresses that have already occurred.
Translated on 11-10-2026, 13:14.
Post18-02-2014, 11:02    Subject: Piston Animation: ARL - Your Opinion Needed Quote
I would be more concerned about the thermal stresses that have already occurred in that area.
icon_smile_thumb_up.gif icon_wink.gif Who knows when the first crack will appear there or in the recess, although the damage on the outer piston bottom looks more like a minor cavitation damage. However, this does not change the fact that the piston needs to be replaced for the reasons mentioned above.
Translated on 11-10-2026, 13:15.
Deus Violentia
Post20-02-2014, 10:43    Subject: Piston Animation: ARL - Your Opinion Needed Quote
I would like to thank you very much for your assessment of the situation icon_biggrin.gif.
BKD GRF
AHF EBF
No new posts Timing Belt: Questions & Opinions Diesel Engine Technology
No new posts Windshield wipers not working, need advice Electrical Systems, Vehicle Electronics, Multimedia
No new posts 2.5 TDI BFC Camshaft Photos - Comments Welcome Diesel Engine Technology
No new posts Polo 9n: Intercooler Modification 6L0805639A - Your Opinion Diesel Engine Technology
