VCDS Error: RT-USB.DLL Missing - Fix Now!
440cui
Post04-10-2020, 14:38    Subject: VCDS Error: RT-USB.DLL Missing - Fix Now! Quote
Hello forum,
Yesterday, I received the above error message. It indicated that I should reinstall the software to fix the problem. After installing the new software for 10 minutes, VCDS started up... everything was working fine again.
Today I want to read different values, but VCDS is reporting the same error as yesterday. I would like to avoid having to reinstall it every time before using it.
Although VCDS reports that the file is missing, I find it twice.
on the computer, in various folders.
WIN7 64-bit.
VCDS HEX - Version 2.
Does anyone have a workaround?
Translated on 17-08-2026, 5:05.
Post04-10-2020, 21:55    Subject: VCDS Error: RT-USB.DLL Missing - Fix Now! Quote
The .dll file usually belongs in the same folder as VCDS.exe, so that the .exe file can find it.
I suspect a rogue antivirus scanner that is blocking access or quarantining the .dll file.
Translated on 17-08-2026, 5:07.
440cui
dieselschrauber likes this.
Post13-10-2020, 1:33    Subject: VCDS Error: RT-USB.DLL Missing - Fix Now! Quote
correctly guessed icon_smile_thumb_up.gif ... Thank you @Dieselschrauber!
Post13-10-2020, 18:17    Subject: VCDS Error: RT-USB.DLL Missing - Fix Now! Quote
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Missing Label: 8Y0920790 - Find Yours Now! On-Board Diagnostics (OBD)
No new posts Ladedruck da, Luftmasse fehlt. Q7 3.0 TDI MKB:ASB Diesel Engine Technology
No new posts Fabia RS: Lacking Power? Performance Review On-Board Diagnostics (OBD)
No new posts GRA Light Off? Seat Altea Troubleshooting. Diesel Engine Technology
