Haldex 3rd Gen Oil Change
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post04-04-2014, 17:30    Subject: Haldex 3rd Gen Oil Change Quote
Today, I had a 2006 Audi S3 8P in my shop, and I was going to change the Haldex oil and filter.
According to Audi, there should be a drain screw at the bottom and a fill screw on the side.
However, neither of those was present. The filter could have been replaced with a cover on the side, with the designation SW 24.
The filling volume should be 0.8 liters.
Can someone tell me how to make a change here?
It's not like the previous version, where the oil is pressed in.
Translated on 10-09-2026, 11:49.
tomsyncro
Post04-04-2014, 20:42    Subject: 4Motion Oil Change: Service & Costs Quote
Hello.
"Should it be the same as it is in my Golf 5 4Motion?"
I have a 5mm Allen screw at the bottom and one at the top left.
Best regards, Thomas from Vienna.
Translated on 10-09-2026, 11:50.
klahaui
Avatar-klahaui
Post05-04-2014, 9:52    Subject: Haldex 3rd Gen Oil Change Quote
Unfortunately, there is no Allen screw there.
Translated on 10-09-2026, 11:51.
tomsyncro
Post05-04-2014, 20:24    Subject: 4 Motion: The Ultimate Guide Quote
Hello.
Thinking is the same.
Best regards, Thomas.
klahaui
Avatar-klahaui
Post06-04-2014, 10:32    Subject: Haldex 3rd Gen Oil Change Quote
It seems it is indeed the 4th generation.
I found a picture that matches the clutch for the S3.
 File size:  155.11 KB
 Viewed:  2268 times
Translated on 10-09-2026, 11:52.
klahaui
Avatar-klahaui
Post24-04-2014, 17:55    Subject: Haldex 3rd Gen Oil Change Quote
The Haldex coupling oil will be completely replaced via the axle oil, starting with generation 4.
There is a filter that is installed on the Haldex system, and it is also very easy to replace using an Allen key.
No new posts Golf 1J1587: Haldex Control Unit Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Haldex clutch/Haldex axle drive 5. Which generation of oil? Transmission, Chassis, Body & Interior
No new posts Haldex Oil Change: Service & Costs Transmission, Chassis, Body & Interior
No new posts Haldex Oil Change: 8900 km / 5500 miles Transmission, Chassis, Body & Interior
No new posts SDI Injection Pump: First Generation On-Board Diagnostics (OBD)
