T4 is going out...
davidshoes
Karma: +6 / -2   Thank you, like it!
Post20-04-2003, 20:23    Subject: T4 is going out... Quote
Our T4 TDI 111kW sometimes cuts out while driving at high speeds (over 160km/h) and restarts after a few hundred meters or so, usually after 10-30 seconds. This often happens when the tank is only about 1/4 full. What could be the cause? Is the diesel foaming so much that it can no longer be sucked in? As I said, everything will be fine again afterwards.
Andy
Post26-04-2003, 23:47    Subject: Error memory...? Quote
and what then is in the error memory...?
Hello
Andy
davidshoes
Post28-04-2003, 11:56    Subject: T4 is going out... Quote
Unfortunately, nothing! And the workshop has no plan!
Post28-04-2003, 12:27    Subject: T4 is going out... Quote
without further consideration, it sounds very much like relay 109 (motor management power supply)...
I don't know if it's even installed in your model.
If you find a relay plate with a '109 - Made in Tunesia' label, that's a likely candidate.
Hello, Rainer
davidshoes
Post30-04-2003, 17:48    Subject: T4 is going out... Quote
The relay has been replaced twice already, but without success...
maniac
Post30-04-2003, 17:56    Subject: T4 is going out... Quote
Did you definitely take a long, sharp right-hand turn before each time?
is a common problem with the T4. It sucks in air.
either fill up the tank or take your foot off the gas in the (sharp) turn.
davidshoes
Post01-05-2003, 11:57    Subject: T4 is going out... Quote
@ Maniac: So, wie ich erwartet habe, er saugt also Luft. Never drive with less than 1/4 of a full tank.
maniac
Post01-05-2003, 20:19    Subject: T4 is going out... Quote
it's enough to make the gas pedal easier to use in such situations (empty tank and long curve). not digital gas. icon_smile.gif
I always drive until the light turns red. No problems.
No new posts Passat gibt Schläge - ESP Leuchte geht an Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K9, MJ 98/99, Motor geht aus, Fehlercode 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Engine won't start, stalls at traffic lights Diesel Engine Technology
No new posts Clutch, sometimes it works, sometimes it doesn't. Transmission, Chassis, Body & Interior
No new posts TDI is shutting down Diesel Engine Technology
No new posts A6 V6 TDI (AKN) geht aus.. Diesel Engine Technology
