Off-Road Suspension for VW Golf 3 Syncro
blackblizzard
Post08-05-2014, 19:47    Subject: Off-Road Suspension for VW Golf 3 Syncro Quote
The shock absorbers on my VW Transporter with Syncro and off-road package should be replaced.
I would like to remove something from the accessories, if possible.
Does anyone know if regular shocks would also fit (perhaps in the front)?
Translated on 26-08-2026, 4:03.
Post09-05-2014, 0:41    Subject: Off-Road Suspension for VW Golf 3 Syncro Quote
To know that, we would need to know what components are installed.
You might provide us with more detailed vehicle information. Then we could determine the part number and use that number to search, for example, on the Sachs website.
Sometimes, the ET number is also embossed on the shock absorber.
Translated on 26-08-2026, 4:04.
blackblizzard
Post09-05-2014, 16:40    Subject: Off-Road Suspension for VW Golf 3 Syncro Quote
The dampers are quite rusty.
I checked out various online retailers for electronic parts and came across Sachs part number 170 128.
Translated on 26-08-2026, 4:05.
Post09-05-2014, 19:20    Subject: Off-Road Suspension for VW Golf 3 Syncro Quote
It's possible that they fit.
Unfortunately, we are missing the OE part number that would allow us to find equivalent parts from Sachs or other manufacturers.
blackblizzard
Post25-05-2014, 12:48    Subject: Off-Road Suspension for VW Golf 3 Syncro Quote
So, I was at the icon_smile.gif.
It should be 535 413 031 C!
Post25-05-2014, 16:34    Subject: Off-Road Suspension for VW Golf 3 Syncro Quote
Then the Sachs Advantage shock absorber should be the one to choose.
It's slightly stiffer than the standard Sachs shock absorber. I used these in my Passat 3B and was very satisfied with them.
Translated on 26-08-2026, 4:06.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Off-Road Suspension: Is It Worth It? Transmission, Chassis, Body & Interior
No new posts T4 Syncro 2.5 TDI: Power Loss Troubleshooting Diesel Engine Technology
No new posts Fuel sensor Passat 3B Syncro/4Motion Transmission, Chassis, Body & Interior
No new posts VW Passat TDI: Combination Instrument Board Repair Transmission, Chassis, Body & Interior
