Reset Service Light: Won't Turn Off?
Go to page: 1, 2  Next
Marco
Post24-04-2004, 19:46    Subject: Reset Service Light: Won't Turn Off? Quote
Hello fellow enthusiasts,
After completing all the necessary maintenance work on my A4 B5, I tried today to reset the longlife service indicator according to Bertil's instructions. I adjusted the following channels according to the instructions for a 6-cylinder TDI engine.
Channel 42 / Value: 15 (Minimum distance to next oil change).
Channel 43 / Value: 35 (Distance until next oil change).
Channel 44 / Value: 730 (Time in days)
Kanal 45 / Wert: 3 (Verw. Öl Qualität Longlife 6 Zyl. Diesel engines)
After that, a quick check of the dashboard, 'Service in 35000km' looked good, I thought, but then when I turn the ignition off and on again, the dashboard tells me 'Service in 15000km' icon_question.gif icon_question.gif icon_question.gif.
I'm probably just too dense to figure this out today. Does anyone have any ideas about what I might be doing wrong or overlooking?
Translated on 29-10-2026, 10:18.
smith2
Post26-04-2004, 8:12    Subject: Reset Service Light: Won't Turn Off? Quote
Hi, you also need to adjust the channel that displays the 'Service due' or 'Service not due' status.
My Skoda Octavia's registration number is 02.
cu smith2
Translated on 29-10-2026, 10:19.
Marco
Post26-04-2004, 8:37    Subject: Reset Service Light: Won't Turn Off? Quote
Hi Smith2,
Okay, I did that. However, Bertil's instructions also state that if '02' is entered, fixed intervals (15000 km) are automatically set. The problem is that I initially see 35000 km displayed, but then, after turning the ignition off and on again, the FIS displays 15000 km.
Translated on 29-10-2026, 10:20.
Post26-04-2004, 9:12    Subject: Reset Service Light: Won't Turn Off? Quote
Marco wrote:
Only in Bertil's instructions does it state that when channel 02 is entered, fixed intervals (15000 km) are automatically set.
First, you need to adjust Channel 2. After that, you can proceed with the LL adjustment.
The thing is, I initially get a reading of 35,000 km -> then, after turning the ignition off and on again, the FIS displays 15,000 km.
After the LL inspection, the minimum interval is initially displayed, and it gradually increases over time to reach the target LL value. This process depends on the driving profile. However, since you haven't driven much since the service, a precise calculation hasn't been performed yet.
Translated on 29-10-2026, 10:21.
Marco
Post26-04-2004, 9:24    Subject: Reset Service Light: Won't Turn Off? Quote
Hi Bertil,
Thank you for the information! I will continue to monitor the FIS. Could you please add this point to the instructions? I think it would be very helpful.
Translated on 29-10-2026, 10:22.
smith2
Post26-04-2004, 9:25    Subject: Reset Service Light: Won't Turn Off? Quote
Sorry, Bertil.
You got to me first.
My answer is not related to yours.
cu smith2
Translated on 29-10-2026, 10:23.
Marco
Post26-04-2004, 9:43    Subject: Reset Service Light: Won't Turn Off? Quote
For vehicles with fixed intervals, completely different channels must be configured.
cu smith2
Hi Smith2,
Okay, seriously, I'm going to re-check the display again, and if it's still not showing correctly, I'll adjust it again. I adjusted channel 02 last, so maybe that's the problem. However, I did see that it displayed 35,000 km, so I'm assuming everything is correct.
Translated on 29-10-2026, 10:24.
Post26-04-2004, 11:21    Subject: Reset Service Light: Won't Turn Off? Quote
Channel 02 must be reset first, both for LL and for non-LL vehicles . For vehicles that support LL, the LL capabilities must then be added.
smith2 wrote:
Sorry Bertil,
My answer does not refer to yours.
That was already clear.
marco wrote:
Hi Bertil,
Thank you for the information! I will continue to monitor the FIS. Can you add this point to the instructions? I think it would be very helpful.
Was soll ich ergänzen? Is this it?
"After the LL inspection, the minimum interval is initially displayed, and it gradually increases over time to reach the target LL value. This process depends on the driving profile."
However, this only applies to AUDI vehicles, as it is not possible to query the remaining mileage for VW vehicles.
Translated on 29-10-2026, 10:25.
Marco
Post26-04-2004, 11:47    Subject: Reset Service Light: Won't Turn Off? Quote
'After the LL inspection, the minimum interval is initially displayed, and it gradually increases over time to reach the target LL value. This process depends on the driving profile.'
This only applies to AUDI, as it is not possible to query the remaining mileage for VW vehicles.
Yes, that's exactly the point I'm making.
Translated on 29-10-2026, 10:27.
Post26-04-2004, 14:15    Subject: Reset Service Light: Won't Turn Off? Quote
Done!
Wolfgang
Post26-04-2004, 18:44    Subject: Reset Service Light: Won't Turn Off? Quote
However, this only applies to AUDI, as it is not possible to query the remaining kilometers for VW vehicles.
And I was just about to ask icon_biggrin.gif.
Translated on 29-10-2026, 10:28.
Marco
Post06-05-2004, 10:14    Subject: Reset Service Light: Won't Turn Off? Quote
To wrap up the topic, after 593 km, there seem to be some initial calculations. The total mileage displayed on the car's computer is now 29,800 km. Let's see what else comes up.
Post06-05-2004, 10:24    Subject: Reset Service Light: Won't Turn Off? Quote
Hi Marco,
Thank you for the information.
Translated on 29-10-2026, 10:29.
hy-fye1
Post25-06-2007, 18:10    Subject: Reset Service Light: Not Working? (Fix Now!) Quote
Hello everyone,
I'm new here and happy to have found you, as I'm having a big problem with resetting the longlife service indicator.
The following problem:
1. In VAG-Com, I select control unit 17.
2. Now, I'm going to click on "Customize."
3. Now I enter channel number 02 and click "read".
4. I am now entering 00 as the new value.
5. Now, I enter channel number 45 and click "read".
6. If I click on "test" now, I get the error message "Error in the 'Test Value' field."
What am I doing wrong? I'm on the verge of a nervous breakdown.
I hope you can help me.
Okay, I have an A4 Avant Quattro 3.0, model 8E, manufactured in December 2002, and I'm using VAG-Com version 3.03.
Markus.
Translated on 29-10-2026, 10:30.
Ross-Tech-Support
Post27-06-2007, 0:00    Subject: Resetting Service Indicator: Not Working! Quote
Are you writing an email...?
...in the email, please include your name, address, and license number. Then we'll see what happens, or not, if we don't receive an email or if you can't provide a valid license number – which is something we can assume based on the error message, because with legitimate VAG-COM versions, this usually works without any problems.
Translated on 29-10-2026, 10:32.
a4b82.0tdi
Post23-10-2017, 21:19    Subject: Reset Service Light: Won't Turn Off? Quote
Hello, I'm new here.
and I am also unable to set channel 2 in control unit 17 from module 1 to 0. I can specify the value or indicate it with up and down arrows, but I cannot execute the change. I receive a message to do it in the main menu. Even when I select and execute the LL-Service (…Rest of the World/Diesel…), the message "Service due!" remains when the engine is turned on and off.
I updated my VDCS software today.
I have tried the suggested solution – resetting Channel 2 to 0 first, and then running the LL service – multiple times, both in that order and in reverse order.
How can I get rid of this "Service due!" message?
Thank you for any help.
Translated on 29-10-2026, 10:34.
No new posts Audi Longlife Service: Your Best Choice Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Some information about the longlife service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG Longlife Oil Standards Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reset Service Light (Cars '98+) On-Board Diagnostics (OBD)
No new posts Service zurücksetzen Audi A3 8p On-Board Diagnostics (OBD)
No new posts Skoda Octavia 1Z: Reset Service Light On-Board Diagnostics (OBD)
No new posts Long Life Service: Your Car's Extended Warranty On-Board Diagnostics (OBD)
