Good morning.
Quote: |
| However, there was always the message: invalid value range. Could this be due to the software version? Will a VCDS update bring improvement? |
It depends on the cause of the message. Some software versions in the control units do not allow certain modifications, or these modifications are not intended, or the corresponding configuration variables are not evaluated.
However, it is also possible that VCDS is simply sending the incorrect modification request.
My advice in such unclear cases is therefore to always test the current beta version of
It can also be helpful to search the web to see if anyone else has had success with the samehttp://www.ross-tech.com/vcds/download/beta/current.html VAG part number (for example, with 03L-906-018 AB, the "AB" is included, so it should be searched with no, one, or two letters at the end!).
