Passat 3B Service Light: What it Means?
pax
Avatar-pax
2000 Volkswagen Passat
Post23-06-2014, 7:11    Subject: Passat 3B Service Light: What it Means? Quote
Why is the instrument cluster displaying a "Service" message? I explicitly reset channel 2 to 0 and saved the setting, but nothing has changed.
Bye.
peace
 File size:  74.02 KB
 Viewed:  1262 times
 File size:  51.47 KB
 Viewed:  856 times
 File size:  94.52 KB
 Viewed:  808 times
Translated on 23-09-2026, 7:54.
Post23-06-2014, 9:45    Subject: Passat 3B Service Light: What it Means? Quote
Channels 40 and 41 also need to be set to 0. Normally, this should happen automatically, but it doesn't seem to be working in this case. You will then need to do it manually.
Translated on 23-09-2026, 7:55.
pax
Avatar-pax
Post23-06-2014, 10:34    Subject: Passat 3B Service Light: What it Means? Quote
I haven't completely reset the service (I only tested channel 2 again, but it was already at 0), but it was last reset in November 2013 at approximately 342,000 km. However, it's beeping again now, and I don't know why, because the limits haven't been reached yet, neither in terms of time nor mileage.
By the way, this vehicle doesn't have a "long life" service interval, but rather a yearly one, with a mileage of 15,000 km.
Bye.
peace
Post23-06-2014, 11:34    Subject: Passat 3B Service Light: What it Means? Quote
The problem is channels 40 and 41; I'm not sure whether the instrument cluster should reset them automatically or not.
If you set both of them to 0, I'm pretty sure everything is okay. icon_wink.gif
Translated on 23-09-2026, 7:56.
Post23-06-2014, 13:01    Subject: Passat 3B Service Light: What it Means? Quote
dieselschrauber wrote:
The problem is channels 40 and 41; I don't know whether the instrument cluster should reset them automatically or not.
Even though I would also assume that the advertisement would then disappear, I still don't quite understand the message.
Pax posted the following in the channels:
- Service interval fixed at 15,000 km and 365 days (channels 42-44).
- Hazards reported since service: 4,800 and 210 days (channels 40-41).
Therefore, I also don't understand why it's now indicating that a service is due, because it should actually still have 9200 km or 155 days until the next service is required.
Greetings.
Guste.
Translated on 23-09-2026, 7:58.
pax
Avatar-pax
Post23-06-2014, 23:23    Subject: Passat 3B Service Light: What it Means? Quote
Yes, absolutely, guste100 - that's exactly what I'm talking about.
I've had the car since 2003, and I believe I've been resetting the service interval using VCDS since around 2005. I don't recall having any similar problems before. Until about 2 years ago, the car was driven between 20,000 and 30,000 kilometers per year. In November 2013, it was the second service, and even then, the annual mileage of 15,000 kilometers per year wasn't reached. Now, I'm wondering if there might be a software bug in the instrument cluster or even in VCDS that could be responsible. Unfortunately, I rarely drive the car now, so it would be good if the service interval indicator works and reminds the current driver to get the service done at the right time.
Perhaps I'll try resetting it and then manually entering the current mileage and days (is that possible?).
Bye.
peace
Translated on 23-09-2026, 8:00.
Post24-06-2014, 16:20    Subject: Passat 3B Service Light: What it Means? Quote
pax wrote:
Maybe I'll try resetting it and then manually entering the current mileage and days (is that possible?).
Yes, that's possible, and I would also try that first.
Translated on 23-09-2026, 8:01.
pax
Avatar-pax
Post29-06-2014, 8:34    Subject: Passat 3B Service Light: What it Means? Quote
I had it automatically reset using VCDS, and then I re-entered the previous values. Now, the instrument cluster has been working normally for a few days and a few hundred kilometers, but I still don't understand the cause.
I'm curious to see if the service will display the information correctly.
Bye.
peace
Translated on 23-09-2026, 8:02.
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ALH vs. LMM: What's the difference? On-Board Diagnostics (OBD)
No new posts Reset Service Indicator Light Diesel Engine Technology
No new posts Reset 6N Service Indicator Diesel Engine Technology
No new posts Oil Change Reset Log: Unclear Instructions On-Board Diagnostics (OBD)
