AGR Valve Problems: Modern Engines & DPF Issues
kossmann
2016 Audi Q3
Post24-07-2014, 14:45    Subject: AGR Valve Problems: Modern Engines & DPF Issues Quote
Hello everyone,
A sealed AGR valve with a metal plate has sometimes worked wonders in older TDIs (e.g., 1Z). Can the same approach be used with modern engines (e.g., CFGx), or are there any problems associated with it?
Is the DPF potentially subjected to greater stress due to a blocked EGR valve?
Translated on 14-10-2026, 16:55.
Post24-07-2014, 16:43    Subject: AGR Valve Problems: Modern Engines & DPF Issues Quote
Meanwhile, engine control units (ECUs) have also become much more sophisticated and will therefore immediately recognize this modification and set an error code. The air mass measured by the mass airflow sensor (MAF) is significantly higher in the partial load range and can no longer be regulated to the desired low target value due to the activation (or deactivation) of the exhaust gas recirculation (EGR) system.
With the error code set, the OBD error light will illuminate, and the next vehicle inspection will fail due to it.
I also had it on my Golf 3 with the AHU engine (to prevent carbon buildup/sludge in the intake manifold). But the only other memory I have of the closed EGR system was the extremely long warm-up times. Therefore, I wouldn't do it again today.
Greetings.
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 14-10-2026, 16:56.
chli1976
Post25-07-2014, 4:41    Subject: AGR Valve Problems: Modern Engines & DPF Issues Quote
You can deactivate the AGR (Abgasrückführung) in the engine control unit, but doing so will invalidate the operating license.
VCDS
Translated on 14-10-2026, 16:57.
Post25-07-2014, 6:03    Subject: AGR Valve Problems: Modern Engines & DPF Issues Quote
Alternatively, you could put in the effort to research past issues instead of rehashing the same old arguments. Besides that, the previous speaker said everything that needed to be said by mentioning the operating license.
Translated on 14-10-2026, 16:58.
No new posts DIY solution for starting engines with VP 37 Troubleshooting & Guides
No new posts VTG Adjustment for VAG TDI Engines Technical Articles
No new posts VAG Engine Specs: Dimensions & Wear Limits Technical Data
No new posts T5 Bumper Holes: Repair & Seal Guide Transmission, Chassis, Body & Interior
No new posts Differences V.A.G. Engines AFN, AHH, AHU Diesel Engine Technology
No new posts Buying guide for TDI engines Diesel Engine Technology
No new posts Engine Swap: BMW E2 CAN Engines On-Board Diagnostics (OBD)
