Klima, Druckschalter, austauschbar, OHNE Klimagerät?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Post26-07-2014, 22:13    Subject: Klima, Druckschalter, austauschbar, OHNE Klimagerät? Quote
HI
Here at the holiday destination, I have an A6 4G that started having problems with the air conditioning for the last 200 km of the 1200 km journey. The button seems to be malfunctioning:
[code]
1 Error found:
00256 - Pressure/Temperature Sensor for Refrigerant (G395)
004 - No signal/communication
Freeze Frame:
Error Status: 01100100
Error Priority: 3
Frequency of Errors: 4
Lost Count: 41
Kilometerstand: 84493 km
Time: 0
Date: 2014.07.26
Time: 17:13:00
The switch should be the one at the front, behind the air conditioning grill?
Can it be replaced without the climate oil escaping, i.e. without special tools for that?
Thank you.
mullemaus
Post27-07-2014, 0:12    Subject: Klima, Druckschalter, austauschbar, OHNE Klimagerät? Quote
Normal, yes. Take it out, put in a new one, and throw the old one away icon_wink.gif
Post27-07-2014, 0:16    Subject: Klima, Druckschalter, austauschbar, OHNE Klimagerät? Quote
Yes, when unscrewing quickly, very little refrigerant comes out, and the same applies when screwing in; first, grease the new O-ring with compressor oil and then screw it in quickly. There is a valve located under the pressure sensor.
Post27-07-2014, 8:17    Subject: Klima, Druckschalter, austauschbar, OHNE Klimagerät? Quote
OK
dann die nexte Frage:
How do I get 4G?
I can see it through the grill. But it seems the gatekeeper also has the key to the grill.
Okay, turn off the grill and I have the various... Cooler ahead of me, is not.
Alternative: Or, if the item is reported as defective, I can verify it.
Post01-08-2014, 21:33    Subject: Klima, Druckschalter, austauschbar, OHNE Klimagerät? Quote
Okay, here's the translation:
Audi is cooling down again.
The sensor was quickly removed and reinstalled.
Hello
Karma: +784 / -0   Thank you, like it!
Post01-08-2014, 22:44    Subject: Klima, Druckschalter, austauschbar, OHNE Klimagerät? Translating...
[Translating...]
No new posts Audi A3 TDI 8L Klima 1.Lüfterstufe Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Are 3C and 1K rims interchangeable? Transmission, Chassis, Body & Interior
No new posts Klimaanlage Druckschalter F129 Transmission, Chassis, Body & Interior
No new posts Golf 5 TDI WITHOUT electronic components. Zuheizer ??? Transmission, Chassis, Body & Interior
No new posts Motorstörung Werkstatt - OHNE Fehler im Speicher Diesel Engine Technology
