Replace AC Pressure Switch: No AC Unit Needed?
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Post26-07-2014, 21:13    Subject: Replace AC Pressure Switch: No AC Unit Needed? Quote
HI.
Here at the vacation spot, I have an A6 4G that wanted to drive the last 200 of 1200 km without the air conditioning. The pressure sensor seems to be malfunctioning.
Code:
1 Fehler gefunden:
00256 - Geber für Kältemitteldruck/-temperatur (G395)
            004 - kein Signal/Kommunikation
             Freeze Frame:
                    Fehlerstatus: 01100100
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 4
                    Verlernzähler: 41
                    Kilometerstand: 84493 km
                    Zeitangabe: 0
                    Datum: 2014.07.26
                    Zeit: 17:13:00
The switch should be located at the front, behind the grill, on the air conditioning condenser.
Can it be replaced without any leakage of the refrigerant, i.e., without the need for special equipment?
Thank you.
Translated on 11-10-2026, 7:17.
mullemaus
Post26-07-2014, 23:12    Subject: Replace AC Pressure Switch: No AC Unit Needed? Quote
Normally, yes. Take it out, put a new one in, and off you go icon_wink.gif.
Post26-07-2014, 23:16    Subject: Replace AC Pressure Switch: No AC Unit Needed? Quote
Okay, quickly unscrew it; only a small amount of refrigerant will come out. Similarly, before screwing it back in, lubricate the new O-ring with compressor oil and quickly screw it in. There's a valve located beneath the pressure sensor.
Translated on 11-10-2026, 7:18.
Post27-07-2014, 7:17    Subject: Replace AC Pressure Switch: No AC Unit Needed? Quote
Okay.
Then, the next question:
How do I get access to 4G?
I can see the thing through the grill. But the doorman also seems to have a similar grill.
Okay, the grill is off, and I have various coolers in front of me, but it's not what I expected.
Alternatively: If the part is reported as defective, I can verify it.
Unplugging it won't make the error any "more permanent":icon_wink.gif
Translated on 11-10-2026, 7:19.
Post01-08-2014, 20:33    Subject: Replace AC Pressure Switch: No AC Unit Needed? Quote
SO.
Audi is cooling down again.
The sensor was quickly removed and reattached.
Greetings.
Translated on 11-10-2026, 7:20.
Post01-08-2014, 21:44    Subject: Replace AC Pressure Switch: No AC Unit Needed? Translating...
[Translating...]
No new posts Audi A3 TDI AC Fan - 1st Speed Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Are 3C and 1K rims interchangeable? Transmission, Chassis, Body & Interior
No new posts Air Conditioner Pressure Switch F129 Transmission, Chassis, Body & Interior
No new posts Golf 5 TDI WITHOUT electronic components. Zuheizer ??? Transmission, Chassis, Body & Interior
No new posts Engine Problems? Workshop - No Error Codes Diesel Engine Technology
