++Passat B7 TDI MKB CFGC VCDS Diagnosis, no data blocks available
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
hharry
Karma: +2 / -1   Thank you, like it!
Post13-10-2014, 22:22    Subject: ++Passat B7 TDI MKB CFGC VCDS Diagnosis, no data blocks available Quote
Hello everyone,
I bought a 2013 Passat Estate two weeks ago.
Now, the engine electronics' data blocks cannot be read out with VCDS 12.12.3, see Screenshot.
Maybe I'm just making a really simple mistake.
Can anyone help me?
Best regards
Harald
 File size:  138.85 KB
 Viewed:  3938 times
Karma: +784 / -0   Thank you, like it!
Post13-10-2014, 22:37    Subject: ++Passat B7 TDI MKB CFGC VCDS Diagnosis, no data blocks available Translating...
[Translating...]
Vielleicht mache ich auch einen ganz banalen Fehler.
No new posts VCDS: On-board diagnostics for VAG vehicles Troubleshooting & Guides
No new posts Diagnosis of Subaru Vehicles Using VCDS Hardware Troubleshooting & Guides
No new posts Diagnose Adapter Eigenbau - On Board Diagnose - DoItYourself Troubleshooting & Guides
No new posts VCDS-Mobile zeigt Messwertblöcke nicht richtig an On-Board Diagnostics (OBD)
No new posts A6 4A keine Diagnose möglich On-Board Diagnostics (OBD)
No new posts Problems, no diagnosis with a Lupo 1.7 SDI AKU, built in ... On-Board Diagnostics (OBD)
No new posts Fabia: No diagnosis possible when factory radio is connec... On-Board Diagnostics (OBD)
