MFA Retrofit: What You Need to Know
WarLord
Post04-10-2003, 13:41    Subject: MFA Retrofit: What You Need to Know Quote
I have a question (again): What is needed to retrofit a Multifunction Display (MFA) to a Passat 35i 3A5? The car has the instrument cluster with the clock and the digital odometer.
Best regards, WarLord.
Translated on 29-09-2026, 10:49.
DocSnydor
Post05-10-2003, 11:37    Subject: MFA Retrofit: What You Need to Know Quote
You definitely need a combination instrument panel for the MFA (Multi-Function Display) and a windshield wiper lever with MFA functionality. I'm not sure what other sensors you might need (e.g., oil temperature), as I'm not certain about that. In any case, you'll need a combination instrument panel that no longer has the connection for the vacuum hose (for fuel consumption).
Translated on 29-09-2026, 10:50.
WarLord
Post05-10-2003, 11:47    Subject: MFA Retrofit: What You Need to Know Quote
You're welcome. I assume the vacuum port is only necessary for gasoline engines to determine the throttle position, correct?
Translated on 29-09-2026, 10:51.
DocSnydor
Post06-10-2003, 8:37    Subject: MFA Retrofit: What You Need to Know Quote
Yeah, that's what I imagine too...
You can actually find those quite often on eBay.
x world one
Post06-10-2003, 9:00    Subject: MFA Retrofit: What You Need to Know Quote
However, I don't think it's a good idea to connect a combination instrument designed for a gasoline engine to a diesel engine. The tachometer reading would be completely inaccurate.
Were instrument clusters with the MFA (Multi-Function Display) common in diesel versions of the Passat estate?
I've been searching everywhere for a Golf3 TDI, and they're incredibly rare.
Spritmonitor
Translated on 29-09-2026, 10:52.
Albrecht
Post06-10-2003, 10:15    Subject: MFA Retrofit: What You Need to Know Quote
Please check out the website of diesel-dirk: www.jagiella.net
Everything is described excellently there!
Albrecht
01/01-08/08 Passat Variant 35i, 08/96, AFN, 94-283Tkm (5.Gg. defekt)
Mampf
Karma: +8 / -1   Thank you, like it!
Post06-10-2003, 18:32    Subject: MFA Retrofit: What You Need to Know Quote
x world one wrote:
Were instrument clusters with the MFA (Multi-Function Display) common in the Passat wagon for diesel models?
MFA (Multifunction Display) was standard equipment on all Passat 3A (35i facelift) models with the GT trim (at least on gasoline and TDI versions - I'm not sure about the TD).
Munch.
Translated on 29-09-2026, 10:53.
DocSnydor
Post07-10-2003, 7:43    Subject: MFA Retrofit: What You Need to Know Quote
By the way, if you can't find a combination instrument for the 35i: The one from the T4 might also fit. (At least in terms of shape, I don't know if there will be any problems due to the 5 cylinders -> incorrect readings icon_question.gif).
Translated on 29-09-2026, 10:54.
WarLord
Post07-10-2003, 13:41    Subject: MFA Retrofit: What You Need to Know Quote
Do you know if the new design works with this, or only the old one? The new design would be another step up in terms of aesthetics (although I think the Passat looks great already). The one from the Golf III is ugly (I wonder if there are any available on eBay for a TDI). Also, what about the mileage? I'll have to reprogram that too (I'd like to have my 167,000 km showing).
Translated on 29-09-2026, 10:55.
DocSnydor
Post07-10-2003, 14:32    Subject: MFA Retrofit: What You Need to Know Quote
What do you understand by 'old form' vs. 'new form'? I'm a bit stuck right now...
And the mileage... that's a tricky thing.
I have an instruction manual on how to supposedly adjust the speedometers on our 35i models, but I haven't tried it yet. You need to create a custom cable (without an interface) and then connect it to the 3 pins on the back of the instrument cluster. The manual claims that you can then use a DOS program to adjust it. If you're interested, I can email it to you (about 1 MB).
'Unfortunately, nothing can be accessed via OBD, as the AI systems are not yet capable of diagnostics.'
Translated on 29-09-2026, 10:56.
WarLord
Post07-10-2003, 19:32    Subject: MFA Retrofit: What You Need to Know Translating...
[Translating...]http://shop.dieselschrauber.de/product_info.php/products_id/45
DocSnydor
Post08-10-2003, 8:00    Subject: MFA Retrofit: What You Need to Know Quote
Oh, you mean for a T4!? Well, that won't fit, not even considering the shape... It looks more like a Golf 4.
Translated on 29-09-2026, 10:57.
No new posts Tempomat (GRA) Golf 5/6/7, Retrofitting Procedure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Do you need a DZR guide? Diesel Engine Technology
No new posts UHV in the Touran - what else is needed? Electrical Systems, Vehicle Electronics, Multimedia
No new posts Shock Absorber Boot: Do You Really Need One? Transmission, Chassis, Body & Interior
No new posts Airbag malfunction, new coil spring needed? Transmission, Chassis, Body & Interior
