Control Unit Not Found: Troubleshooting Guide
Thomas K
Post27-09-2014, 17:17    Subject: Control Unit Not Found: Troubleshooting Guide Quote
I was just trying to read the error memory in our VW EOS using the latest software (VCDS RKS 1212). The software simply can't find any control units, and therefore can't detect any errors. This happens whether I query individual devices directly or start a general scan.
Vehicle: VW EOS 2.0 TSI, engine code BWA, manufactured in 2006.
When attempting to read the control units on a VW Bora, everything worked perfectly.
Does anyone have any idea what might be causing this?
Gruß Thomas
VW EOS 2,0 TSI; BWA; Bj. 06/2006
September 2020 ca. 180.000km
VW Bora Variant, AJM, Bj. 04/2001
04/2016 verkauft mit 378.000km
Translated on 26-09-2026, 12:11.
Post28-09-2014, 14:19    Subject: Control Unit Not Found: Troubleshooting Guide Quote
If you may have accidentally changed any VCDS settings, please click the "Reset to Defaults" button in the program settings and try again.
If that doesn't work either, please click the "Test" button in the program settings (with the ignition on) and post a Screenshot of the dialog box that appears.
Translated on 26-09-2026, 12:13.
Thomas K
Post29-09-2014, 21:58    Subject: Control Unit Not Found: Troubleshooting Guide Quote
Hello Rainer,
Unfortunately, my wife had the EOS today, so I won't be able to do that until tomorrow.
I will then follow your advice and reset the settings again.
I started the engine in the EOS.
Gruß Thomas
Post30-09-2014, 9:14    Subject: Control Unit Not Found: Troubleshooting Guide Quote
I just checked, and your diagnostic system doesn't support CAN. It says it's not possible. I'll send you an email about it.
Translated on 26-09-2026, 12:14.
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Hard landing - no error entry - troubleshooting? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 2.5 TDI G28 - No Signal Diesel Engine Technology
No new posts TDI Engine: Won't Accept Fuel? Troubleshooting Diesel Engine Technology
No new posts VW AAZ: No Acceleration Below 1/3 Throttle Diesel Engine Technology
No new posts No contact with MSG On-Board Diagnostics (OBD)
