BKD 2.0 16V TDI: Turbocharger boost pressure limit exceeded (resolved)
Apfelsaft
tdi_power,
Post26-08-2014, 15:13    Subject: BKD 2.0 16V TDI: Turbocharger boost pressure limit exceeded (resolved) Quote
Hello everyone,
I've now spent about 12 hours troubleshooting an issue on a 2.0 TDI engine with the engine code BKD.
Main problem: Charger pressure - exceeded regulation limit.
The pressure is exceeding 2601 millibars, so it's constantly in emergency mode.
The error only occurs during uphill driving and overtaking maneuvers -> This indicates a high load and a prolonged period of high boost pressure.
AB is rarely/not driven; only country roads are used.
It's a 16V engine without a particulate filter.
Particle accelerator by Garret: 1749VA.
Laufleistung 200tkm. Year of construction: 2005.
Here's the history:
Problem: The turbocharger is making a noticeably loud whistling noise.
Idea: Bearing damage (in the turbocharger), but let's research first. Result -> Replace the EGR pipe.
Work: AGR pipe replaced, part number: 03G 131 521 T.
Result: Pipes unchanged. The old pipe appeared to be slightly leaky, but the subsequent leak test did not confirm this! Apparently still tight after 200,000 km.
Idea: Replace the turbocharger with a used one from another vehicle (1749VA).
Arbeit: Turbo getauscht, Pfeifen weg! icon_smile.gif
Problem 1: Whistling sound reappears after 2 weeks icon_evil.gif.
Problem 2: Again, emergency stop due to overpressure exceeding the sensor range, > 2601 mbar absolute. icon_evil.gif icon_evil.gif
Now, the extensive troubleshooting process began, focusing on what was already known.
Vintage, very smooth-running loader. Used, but I cleaned the exhaust side, and it was working perfectly.
The pressure vessel was checked for leaks using a vacuum pump and pressure gauge. The pressure remained constant at -0.7 bar after 30 seconds, indicating the membrane is functioning correctly.
Please refer to the video attached, where I re-checked the functionality today while it was still installed, to be 100% certain!
Idea: The N75 sensor might be failing at this point, considering it has 200,000 km on it.
Work: Replace the old valve block: 6Q0906625 with: 6Q0906625E (see picture!).
Problem 1 & 2: Unchanged, emergency mode due to boost pressure > 2601 mbar absolute icon_evil.gif.
Idea: Check the hose from the valve block (6Q0906625) to the air filter, replacing the new one with the old one if necessary, to ensure proper airflow, as this vents the pressure sensor of the turbocharger.
Work: Hose connected to the intake manifold; checked the nozzle for blockage and proper flow.
Result: No abnormalities found; it is clear that the hose is in perfect condition.
Idea: Research suggests that the hoses leading to the pressure chamber may become softer at bends (this is my own HYPOTHESIS!!) and therefore contract, preventing the vacuum inside the pressure chamber from escaping.
Arbeit: Austausch des Schlauches vom Ventilbock zur Druckdose (so ne Scheiße wenn dort niergends Platz ist... (CROSS-ENGINE)
Note: I was too lazy to cut the 2.5-meter (universal) hose, especially since it might not even be defective. If I had cut it, I would have damaged it.
Note: The original (DRECKSSCHLAUCH) has 2 nipples in the middle and actually consists of 3 pieces. The airflow (from my mouth) was also quite bad icon_evil.gif there... A quality product, you might say, to put in your G******? No wonder that you read online that the first VNT TDI engines, like the AFN, adjusted their boost pressure peaks faster...
Result: The error remains unchanged for now.
Work 1: Because I was becoming increasingly unsure about the VTG (vibration transmission group) system, in this work process, I created a VTG video to check its functionality while it was installed.
Okay, I'll shorten the hose to the correct length and bring along a T-piece with a pressure gauge. This gauge will also indicate vacuum during the test drives.
Result: No more errors. It now regulates the target pressure and no longer exceeds the absolute pressure of 2601 mbar.
"The hose collapsed due to vacuum pressure at some point, meaning the hose to the vacuum actuator wasn't of particularly high quality. When the N75 valve was opened/is opened at the top, the hose was likely still being pinched by the vacuum reservoir in the pressure sensor, resulting in the turbo being permanently and excessively activated after a full-throttle run. This caused it to generate an abnormally high boost pressure (not measured by the LDA, just based on the data blocks)."Note: I still find it a bit strange that the error persisted even with a very long tube. The tube, which was the same length thanks to the T-piece and LDA (I had used the cut-off piece specifically for the LDA), still had the error, but then (suddenly) the error disappeared.
Appendix:
Video VTG with vacuum hand pump.
Image of a ventilation control block, including the N75 valve, showing both old and new versions.
Log1: I have a log where the turbocharger is charging to 2601 mbar until it enters a failsafe mode, and then there's a second attempt after the engine restarts.
Log2: During the test drive, I had just disconnected the LDA, and it no longer goes into limp mode, and it only exhibits brief overboosts, not prolonged 2601 errors.
I will report on the situation in the coming weeks. Suggestions and further questions are welcome, and I hope that my experiences will help some people with troubleshooting.
The vehicle is not mine, so the flow of information regarding the current situation, whether further issues will arise or not, is a bit slow.
Best regards from Lower Franconia, your apple juice.
BKD 2.0 16V TDI: Turbocharger boost pressure limit exceeded (resolved) - 20150826_114018_komp.mp4
 VTG mit Vakuumpumpe
 File size:  2.02 MB
 Viewed:  16541 times
LOG-01-003-010-011_bkd_6.CSV
 ohne Fehler.
ohne Fehler.
 File name:  LOG-01-003-010-011_bkd_6.CSV
 File size:  21.09 KB
 Downloaded:  996 times
LOG-01-003-010-011_BKD_2.CSV
 mit Fehler.
mit Fehler.
 File name:  LOG-01-003-010-011_BKD_2.CSV
 File size:  16.15 KB
 Downloaded:  891 times
 Ventilblock 6Q0906625 und 6Q0906625E (NEU)
 File name:  6Q0906625(und E) Ventilbock.jpg
 File size:  2.72 MB
 Downloaded:  5849 times
Translated on 08-07-2026, 9:00.
Apfelsaft
Post08-10-2014, 7:24    Subject: Problems persist Quote
Good day.
Unfortunately, the problem still persists, even though the "emergency runs" are happening less frequently.
What else could I check?
Could the turbocharger pressure sensor really be defective, or even the control unit?
I highly doubt it, but I simply can't seem to get a handle on this problem.
Best regards, Apple.
Translated on 08-07-2026, 9:08.
Karma: +807 / -0   Thank you, like it!
Post08-10-2014, 7:57    Subject: BKD 2.0 16V TDI: Turbocharger boost pressure limit exceeded (resolved) Quote
Could you please make a video of the VTG (Variable Turbine Geometry) valve, showing it being alternately opened and closed in its basic setting mode (using measurement block 10 or 11 from the engine control unit)?
It might be possible to deduce where the problem lies by observing the movement of the lever.
Most often, it's simply a mechanical jam caused by rust or damage to the VTG (variable geometry turbine) due to foreign objects.
Translated on 08-07-2026, 9:09.
Post08-10-2014, 10:29    Subject: BKD 2.0 16V TDI: Turbocharger boost pressure limit exceeded (resolved) Quote
Fehler tritt nur bei Bergfahrten und Überholvorgängen auf -> Hohe Last - lange Zeit voller Ladedruck gefordert.
Prolonged periods of high load result in high exhaust gas temperatures.
I think the exhaust manifold from the TL is simply warped or uneven.
Therefore, the VTG (variable turbine geometry) becomes stuck when the boost pressure is slightly reduced, especially when higher temperatures are present.
/viewtopic.php?t=25869&highlight=vtg&start=24
In picture 3 and picture 5, there is/was a hump that has been removed. This can be easily verified using a depth gauge.
Translated on 08-07-2026, 9:10.
Apfelsaft
Post08-10-2014, 11:16    Subject: BKD 2.0 16V TDI: Turbocharger boost pressure limit exceeded (resolved) Quote
@dieselschrauberViewing profile: dieselschrauber
I had just installed the turbocharger, and before that, I had thoroughly cleaned the variable geometry turbine (VTG), making sure it was open and clean. In that condition, it was working perfectly. Therefore, I can rule out the typical issue of carbon buildup and oil sludge causing it to seize.
@AutoserviceViewing profile: Autoservice
Yes, unfortunately, my suspicion also went in that direction at one point.
Kann man so einen Schaden instandsetzten lassen? (wenn ja wo? PM?
What also bothers me, as mentioned in the initial post:
The turbo now, like the previous one (original), makes a deep whistling noise when starting from a standstill, which it didn't have for the first couple of weeks. If I now install a new turbo, what if the same symptoms reappear? I'm wondering if some factor still present in the car might be triggering these symptoms, and how it relates to the high boost pressure.
Best regards, Apfel.
Translated on 08-07-2026, 9:12.
Post08-10-2014, 13:39    Subject: BKD 2.0 16V TDI: Turbocharger boost pressure limit exceeded (resolved) Quote
If you've already disassembled the turbocharger, you should be able to fix it yourself.
Place a metal ruler or something similar that is straight across the exhaust manifold. Then, you can use a caliper to measure the depth and determine any unevenness.
I roughly straightened it out back then using a drill and a grinding wheel. The rest I smoothed and shaped using filler primer and a broken piece of a body file.
Accurately 100%, that can only be achieved with a milling machine icon_smile.gif.
Regarding the condition of your new used TL, I have nothing to add.
If he's already been running for 2 weeks without crying, well, you just don't know.
Translated on 08-07-2026, 9:13.
This topic is locked, you cannot edit or reply. Third gear shifting/synchronization (resolved) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0299 Error: Boost Control System Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Boost Pressure Too High - Need Help! Diesel Engine Technology
No new posts 575 limit exceeded Diesel Engine Technology
No new posts A6 4B 2.5 TDI AGR limit exceeded On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Boost Pressure Control: Limit Exceeded Diesel Engine Technology
