Measuring boost pressure with VCDS RKS 12.12
Oellappen
Karma: +0 / -2   Thank you, like it!
Post27-11-2014, 21:35    Subject: Measuring boost pressure with VCDS RKS 12.12 Quote
How do I measure the [something] on a Golf 4 1.8T with engine code AUM?
record the boost pressure?
Translated on 20-07-2026, 4:10.
mullemaus
Post27-11-2014, 22:04    Subject: Measuring boost pressure with VCDS RKS 12.12 Quote
Pressure = Measurement data block 115.
Translated on 20-07-2026, 4:11.
Oellappen
Post27-11-2014, 22:13    Subject: Measuring boost pressure on a Golf 4 1.8T (AUM engine) using VCDS RKS 12.12 Quote
Thank you for the quick response; I'm still new to this field.
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Measure Boost Pressure with VAG-Com On-Board Diagnostics (OBD)
No new posts Measuring boost pressure On-Board Diagnostics (OBD)
No new posts Measuring VCDS compression? On-Board Diagnostics (OBD)
No new posts Exhaust Temperature Measurement On-Board Diagnostics (OBD)
