schlauchdruide Guest
13-11-2014, 10:49 Subject: Audi 3.0 TDI Engine Failure: Causes & Symptoms |
As can be seen in the picture, the pistons are from cylinders 4 through 6.
suffered greatly, and you can see the melting damage.
The injectors and almost all of the exhaust valves are burned.
Cylinders 1-3 are not affected.
What could be the reason that only this cylinder bank is affected? All the injectors are still original and from the first production run. (AB)
Is it possible to upload a picture from a smartphone?
If not, I will upload them later, if necessary.
Translated on 07-09-2026, 22:30.
Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
13-11-2014, 11:01 Subject: Audi 3.0 TDI Engine Failure: Causes & Symptoms |
Quote: | | Is it possible to upload a picture from a smartphone? |
Yes, use the "Select file+" button.
Translated on 07-09-2026, 22:31.
Profile PM WWW Garage |
vwSchrauber Profi-Schrauber
13-11-2014, 12:39 Subject: Audi 3.0 TDI Engine Failure: Causes & Symptoms |
Swirl flaps
13-11-2014, 12:53 Subject: Audi 3.0 TDI Engine Failure: Causes & Symptoms |
Please explain the throttle valves to me.
13-11-2014, 13:02 Subject: Audi 3.0 TDI Engine Failure: Causes & Symptoms |
Perhaps one cylinder bank received insufficient combustion air, which caused it to overheat.
Translated on 07-09-2026, 22:32.
13-11-2014, 13:03 Subject: Audi 3.0 TDI Engine Failure: Causes & Symptoms |
There is one swirl flap unit per cylinder bank. The servomotors use plastic gears that will eventually suffer from tooth breakage.
If the servomotor's position monitoring system fails to detect the correct position, the swirl flaps will remain closed even under high load, and the affected cylinders will not receive enough air (because the intake channel is not open).
Due to the lack of air, the combustion process gets closer to the piston material, and the exhaust gas temperature also increases significantly. Since "healthy" exhaust gases come from the other cylinder bank, and older EU4 engines were not subject to such strict monitoring, an error is usually not displayed until half of the engine is completely damaged.
EDIT: There is a lookup table (map) for the swirl flap position. Those who want to prevent this problem from occurring in the first place can have a competent chip tuner "adjust" this map, so that the frequency of adjustment and thus the risk of failure is reduced.
Translated on 07-09-2026, 22:33.
13-11-2014, 13:16 Subject: Audi 3.0 TDI Engine Failure: Causes & Symptoms |
That must be the exact problem, as the exhaust temperatures were so high that the cables in the area of the catalytic converter had melted together, including the connector for the crankshaft position sensor; it was just a clump of melted material.
Thank you very much!
Now I can finally go back to sleep.
Translated on 07-09-2026, 22:34.
13-11-2014, 14:56 Subject: Audi 3.0 TDI Engine Failure: Causes & Symptoms |
Of course, this also means that the DPF (Diesel Particulate Filter) was likely regenerated more frequently, because somewhere the soot that is produced in greater quantities due to the lack of air has to go... and that also contributes to high exhaust temperatures.
The 2.7/3.0 TDI engines already have air-gap insulated (double-walled) exhaust manifolds. So, it shouldn't get *that* hot around there... or is the melted connector located at the back, near where the (single-walled) exhaust pipes lead to the turbocharger?
Translated on 07-09-2026, 22:35.
13-11-2014, 15:38 Subject: Audi 3.0 TDI Engine Failure: Causes & Symptoms |
Absolutely. The connector is attached to the transmission bell housing. The catalytic converter and the exhaust pipe are located in this area. Even the catalytic converter shows significant signs of corrosion.
Thank you again.
Translated on 07-09-2026, 22:36.
chli1976 Profi-Schrauber
21-11-2014, 6:27 Subject: Audi 3.0 TDI Engine Failure: Causes & Symptoms |
Can you upload the pictures, please?
VCDS
Tagessuppe and chli1976 likes this. |
27-11-2014, 16:54 Subject: Audi 3.0 TDI Engine Failure: Causes & Symptoms |
Thank you for the pictures!
It seems like you were lucky, and the cylinder walls are undamaged.
A little bit of tinkering, new pistons installed, and it works again  .
Translated on 07-09-2026, 22:37.
