Nozzles, Tuning: New & Best Options
tim27
Post29-04-2003, 10:18    Subject: Nozzles, Tuning: New & Best Options Quote
This week I'm getting my 'tuning nozzles' for my A6, I think they are 216 size. I'm going to install them directly and see what the engine can do. I hope 1.1 bar of boost pressure will be enough!
Translated on 17-09-2026, 2:31.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post30-04-2003, 6:20    Subject: Tuning: New Nozzles, Performance Upgrades Quote
tim27 wrote:
This week, I'm getting my "tuning nozzles" for my A6; I think they are 216s. I'm going to install them directly and see what the engine can do. I hope 1.1 bar of boost pressure will be enough!!
Hi Tim. Which vehicle are you planning to install the nozzles in?
I've been considering installing AGR, AFN, or multi-valve injectors in my car for a while now. The only thing that's been holding me back so far is that I'm not sure if the spray pattern is the same.
Please definitely share your experiences with me.
Translated on 17-09-2026, 2:32.
Stefan
Post30-04-2003, 10:02    Subject: Nozzles, Tuning: New & Best Options Quote
Quite a bit has already been written about that here.
Without software customization (except for standard software), it won't work.
Translated on 17-09-2026, 2:33.
Tagessuppe
Post30-04-2003, 11:37    Subject: Nozzles, Tuning: New & Best Options Quote
Then please show me where it states that the nozzles have the same spray pattern.
Best regards.
Translated on 17-09-2026, 2:34.
Stefan
Post30-04-2003, 12:09    Subject: Nozzles, Tuning: New & Best Options Quote
Do you look here: /search.php
Tagessuppe
Post30-04-2003, 13:59    Subject: Nozzles, Tuning: New & Best Options Quote
Oh dear, I don't think this is going to work.
I've been there before. :-/
Translated on 17-09-2026, 2:35.
Post30-04-2003, 20:29    Subject: Tuning: New Nozzles, Performance Upgrades Quote
tim27 wrote:
I'm getting my "tuning nozzles" for the A6 this week; I think they are 216s
Hi Tim,
AFAIK, the most powerful TDI engine with the appropriate injectors in the A6 "only" has 103 kW.
The VW Bus TDI with the 216 engines, but with an output of 111 kW.
Therefore, the A6 nozzles might also be a bit smaller than 216... icon_eek.gif icon_question.gif (but I don't know anything for sure).
Translated on 17-09-2026, 2:36.
Post01-05-2003, 8:05    Subject: Tuning: New Nozzles, Performance Upgrades Quote
Tagessuppe wrote:
I've also been thinking for a while about installing AGR, AFN, or multi-valve injectors in my car.
The only thing that has held me back so far is that I don't know if the spray pattern is the same.
Hi.
I once compared the
spray pattern} of the 216 T4 injectors with that of the AFN injectors by inserting small pieces of 0.15 mm copper-coated wire into opposing holes.
As far as one can tell from this "rough estimate," the holes in these nozzles are already aligned, so the larger nozzles in the AFN (air fuel nozzle) will likely also aim at the piston burn pit.
This initially doesn't allow us to make any statements about the beam length, but based on the photos in another thread about nozzles, the dimensions of the combustion chambers are likely very similar, so the spray patterns should at least be approximately correct.
While it may not necessarily apply to the AGR (Arbeitsgemeinschaft für regenerative Energien), it might be a good starting point.
Translated on 17-09-2026, 2:38.
tim27
Post01-05-2003, 8:16    Subject: Nozzles: Types, Uses & Applications Quote
I'm going to install it in a 1Z, and then we'll see what it actually does.
Translated on 17-09-2026, 2:39.
Post01-05-2003, 19:56    Subject: Nozzles: Types, Uses & Applications Quote
tim27 wrote:
I will install it in a 1Z, then we will see what it actually brings.
Among other things, there will likely be a lot of soot if you already have a chip tuning installed... and possibly an even earlier failure of your engine icon_twisted.gif.
Okay, I'm ready. Please provide the German text you want me to translate.
Translated on 17-09-2026, 2:40.
Post03-05-2003, 10:05    Subject: Nozzles, Tuning: New & Best Options Quote
Hi Stefan,
Meanwhile, initial "verified" experiences regarding nozzle replacement without software adjustments show that it (in practice) can actually work icon_wink.gif.
Translated on 17-09-2026, 2:41.
No new posts Identify 216 Nozzles: A Guide Diesel Engine Technology
No new posts AFN adjustment values: How to set them. Diesel Engine Technology
No new posts Nozzle Replacement: How to Properly Secure Diesel Engine Technology
No new posts .216 Injectors: 1Z Engine Experiences & Reviews Diesel Engine Technology
