AAZ Oil Pressure Low: Engine Damage?
LaurenzBo
Post03-11-2014, 11:19    Subject: AAZ Oil Pressure Low: Engine Damage? Quote
My old GIII Variant (chassis number 0600 942, manufactured in 1994) with over 550,000 km on the clock has been running like a clock until recently (also thanks to the oil cooler and intercooler, which were installed for the last 300,000 km for police use). A month ago, I replaced the oil cooler hose due to a minor leak at the connection. The new hose has a metal mesh sheath and is specified for 10 bar and 160°C.
"This one burst on me yesterday and sprayed oil everywhere. I stopped the engine after about 500 meters (roughly 30 seconds) and haven't moved it since. The noise was still normal until it stopped. Before I try driving again after replacing the hose, I have a question:"
What kind of damage should I expect after 30 seconds without oil pressure? The engine speed is below 1600 RPM, with almost no load, but the engine is hot due to a stress test performed after fixing a coolant system leak.
What should I definitely check before I start test driving?
If there's a chance the engine can be salvaged, I plan to replace the connecting rod bearings, crankshaft bearings, oil pump, possibly the hydraulic lifters, and potentially re-grind the valves.
I would appreciate any expert advice.
Translated on 23-10-2026, 14:32.
vwSchrauber
Post03-11-2014, 11:29    Subject: AAZ Oil Pressure Low: Engine Damage? Quote
If you want to be sure, remove the oil pan and check the connecting rod bearings.
In my opinion, vehicles with that many kilometers (550,000 km) should definitely be checked, and it's a good way to ensure everything is in good condition.
Warning: Connecting rod bolts are for single use only!
Translated on 23-10-2026, 14:34.
Karma: +591 / -0   Thank you, like it!
Post03-11-2014, 19:12    Subject: AAZ Oil Pressure Low: Engine Damage? Quote
Hi!
I think nothing happened. Also, the oil wasn't completely drained all at once. The people I know who ran out of oil usually only made it about 2 kilometers before it started making a loud noise.
Whether you remove the oil pan, etc., is up to you.
I'll reassemble it quickly first and see if anything rattles.
Then, measure the oil pressure.
I don't know this engine very well.
However, there are also oil pumps where the pressure relief valve can get stuck, and the oil pressure can become too high, which can cause a hose to burst.
If the reading is too low, you can still take care of the connecting rod bearings.
I'd say that 150 euros and a few hours of work would be reasonable, but I would only do that with an older engine if it's absolutely necessary and after careful consideration.
Translated on 23-10-2026, 14:36.
LaurenzBo
Post07-11-2014, 21:54    Subject: Oil Leak: Causes, Repair & Prevention Quote
Well, that's encouraging news. Let's hope for the best.
I was planning on replacing the connecting rod bearings anyway, probably after the car passes the technical inspection. How critical are the crankshaft bearings and the intermediate shaft bearings? Otherwise, I'm also considering replacing the valve seats, installing a new head gasket and oil pump, valve stem seals, hydraulic lifters, and possibly the piston rings.
I don't know if the hose burst was due to excessive oil pressure; I should measure it. It might also have been overheating of the oil. I had some serious cooling problems before this:
- Two years ago, I had the glow plugs replaced by Bosch service, and since then, there has been a weak, undetectable coolant leak.
- It became annoying last year (it would leak every few days), and despite searching, I couldn't find the source, so I tried using a radiator sealant.
- It kept running anyway. I replaced the rusted metal pipe on the engine block, but that didn't fix it. Eventually, I found the cause: the Bosch service had cracked the coolant hose fitting on the front of the engine head, near the temperature sensor housing, creating a long crack. So much for quality workmanship. I replaced the plastic fitting.
- Water continued to leak. The plastic hose on the driver's side was also replaced; it had two cracks at the seam. The coolant only lasted for another 5-10 kilometers.
- It was reasonably tight. However, it was also likely the lid on the expansion tank with its pressure relief valve (radiator seal icon_sad.gif), and due to the several times the coolant boiled over, the thermostat also became stuck. So, on the second to last trip, while stuck in traffic on the highway shortly after the entrance ramp, there was a loud noise, and the heater heat exchanger dampened my feet with a Turkish sauna effect.
- Carefully refilled the coolant every few kilometers (having driven home from a carp pond), then replaced the heat exchanger (which went surprisingly well, even though half the car had to be disassembled) and tested the thermostat (it was stuck closed, so I freed it up). But it didn't help.
During the test drive, the lower radiator hose remained cold, the water boiled after a short period of heavy load, and then the oil hose burst. After being absolutely reliable for many tens of thousands of kilometers, this car is now showing signs of weakness.
I suspect the oil got extremely hot, and a significant portion of the engine's cooling was being handled by the oil cooler when the water in the block boiled. That might have damaged the hose. Well, in any case, this now effectively means an oil change is needed.
I will report on the results of this repair frenzy.
Translated on 23-10-2026, 14:40.
Post07-11-2014, 22:14    Subject: AAZ Oil Pressure Low: Engine Damage? Quote
Interestingly, whenever I read or hear about AAZ engines, I always think about heat damage caused by a defective head gasket or cracked cylinder heads.
Have you checked the water pump for proper flow? You should consider replacing the thermostat.
Then check how often the coolant pressure builds up again before you waste your energy on possibly pointless repairs.
Translated on 23-10-2026, 14:44.
LaurenzBo
Post08-11-2014, 9:22    Subject: Water Pump - ZDK Quote
The cylinder head of the AAZ engine in the TD is thermally critical (without an intercooler), which is why I installed an intercooler from a TDi. The head gasket and cylinder head are probably okay - there's no water in the oil, no bubbling in the coolant when the engine is running, and no white smoke from the exhaust. The water pump is likely working because the heating system works perfectly with sufficient coolant, so the circulation is functioning.
The thermostat will be replaced along with the faulty oil hose, and then we'll see how it goes.
Translated on 23-10-2026, 14:45.
Post08-11-2014, 9:42    Subject: AAZ Oil Pressure Low: Engine Damage? Quote
Where is the oil-carrying hose located on the oil cooler in the AAZ engine?
Post08-11-2014, 12:59    Subject: AAZ Oil Pressure Low: Engine Damage? Quote
The head of the AAZ engine in the TD is thermally critical (without an intercooler), which is why I installed one from a TDI.
Translated on 23-10-2026, 14:46.
Post08-11-2014, 17:48    Subject: AAZ Oil Pressure Low: Engine Damage? Quote
Herbert wrote:
Where is the oil-carrying hose on the oil cooler for an AAZ engine?
Post09-11-2014, 7:26    Subject: AAZ Oil Pressure Low: Engine Damage? Quote
Right, as he mentioned above.
It would be interesting to see a diagram of the oil circulation system, along with the actual oil pressure at low RPMs and with an old oil pump.
But again, regarding
the head of the AAZ engine in the TD is thermally critical (without an intercooler), that's why I installed one from a TDI.
Do you mean the cylinder head or the intercooler?
In the first case - doesn't the AAZ engine have pistons with flat tops? With a DI head and injectors mounted directly on top, there wouldn't be a combustion chamber anymore. You wouldn't have to worry about thermal stability; the holes in the piston crown would take care of that pretty quickly.
Did you install an intercooler?
If the engine is running, and assuming the oil pump is working correctly and the oil pressure is normal, I wouldn't mess with the connecting rod and crankshaft bearings. Doing so won't improve them, and it's questionable whether you can even find replacement parts. Also, if the compression is good (with an AAZ head), you don't need to consider replacing the piston rings.
Translated on 23-10-2026, 14:48.
Post09-11-2014, 16:54    Subject: AAZ Oil Pressure Problem: Engine Damage? Quote
LaurenzBo wrote:
...also thanks to the oil cooler and intercooler for the last 300,000 km...
Translated on 23-10-2026, 14:50.
Post09-11-2014, 19:08    Subject: AAZ Oil Pressure Low: Engine Damage? Quote
vwSchrauber
Post11-11-2014, 12:38    Subject: AAZ Oil Pressure Low: Engine Damage? Quote
If the engine is running, and if the oil pump is working correctly and the oil pressure is normal, I wouldn't mess with the connecting rod and crankshaft bearings.
Warning: This may not be obvious - I know of a few cases where the oil pressure seemed fine, so the oil pressure warning light went out shortly after starting, but a broken connecting rod still caused a catastrophic engine failure.
Reason: All the connecting rod bearings were worn out, and one of them eventually failed.
They don't get any better because of that, and it's questionable whether you would even receive any parts
Do you easily find parts...? There are even still parts available for the older 1.6 engines icon_smile.gif.
Translated on 23-10-2026, 14:51.
Post11-11-2014, 19:09    Subject: AAZ Oil Pressure Low: Engine Damage? Quote
Edit: Contributions corrected, meaningless content deleted icon_biggrin.gif.
Regarding the hose (pressure-resistant up to 10 bar), I initially suspect a material defect.
Translated on 23-10-2026, 14:52.
LaurenzBo
Post21-11-2014, 20:40    Subject: AAZ Restoration: The Sequel Quote
Also, der geplatzte Ölschlauch war meine Dummheit. Ich hatte 12mm-Hydraulikschläuche mit guten Schellen (nicht aus dem Baumarkt) verbaut, und einer hatte am Anschluss zum Thermoventil zwischen Ölkühler/Kühlwasser und Ölfilter gesaut. Wollte es gut machen und habe einen auf 140°C und 10Atü spezifizierten Hydraulikschlauch eingebaut, der einen geflochtenen Metalldrahtmantel hatte und so gut geschützt schien. Mit sehr guten Schellen 19-21mm auf Thermoventilanschluss und Ölkühler (unten vor dem Wasserkühler im Stoßfänger eingebaut) angeschlossen. Die gingen kaum auf das Drahtgeflecht drauf (auch mit Klebeband zum einfädeln fixiern war eine miese Pfriemelei). Saßen dann aber, fingen aber leider nach ein paar Tagen das lecken an, weil sie einen Tick zu weit waren. Also 17-19mm Schellen bester Qualität verbaut und dafür die Metallgeflechthülle am Anschluss das nötige Stück gekürzt. War percompactly.
What I overlooked in the oil mess was that this hose, in its cross-section, didn't have any textile reinforcement - the metal mesh was necessary to withstand the pressure! So, it consistently burst a few days after being installed, right after the clamp new_cry.gif. That's how you create extra work.
Also 75cm vom vorherigen Hydraulikschlauch mit den guten 17-19mm-Schellen eingebaut, neues Öl rein. Beim ersten Starten festgestellt: Kühler war jetzt auch undicht, hat an dem obersten Gummipropfen im Anschlussformteil richtig rausgespritzt (Ölbad oder einfach nur Pech?). AlSure, here's the translation:
"so ersetzt." -> "so replaced."
The engine runs wonderfully. There's no knocking, just a quiet, almost silky humming sound at idle and under load when revving. Seems like I'm lucky. It's truly amazing what these parts can handle. I once had a Ford Fiesta with a gasoline engine where the oil pump screws came loose, and suddenly all the oil pressure was gone. I drove another डेढ़ kilometers home with it, and it even stalled on the last hill, right at the top (a horrible sound). I rolled downhill with the momentum, let it cool down, removed the oil pan, tightened the oil pump, put in new oil, and it ran like new for tens of thousands of kilometers before it was scrapped due to two externally caused total losses, right before the planned decommissioning (the same insurance company had to deal with different opponents within three weeks, and they couldn't believe it, but it was absolutely clear). And the initial damage was repaired (the trunk lid wouldn't close anymore, so the lower crossmember at the rear was hammered back into shape with a 10kg sledgehammer).
Well, let's hope the AAZ engine handled the oil pressure loss well.
Unfortunately, the cooling problem persists. Everything appears sealed from the outside, but it still requires approximately 1 liter of coolant every 100 kilometers on the highway. The new radiator remains cold at the bottom, despite the new thermostat valve. However, it can travel 120-135 kilometers on a flat road with a coolant temperature of 75°C, but the temperature quickly rises during periods of high load. If you reduce the load in time, the temperature drops again. The heater works, so the small circuit is functioning. All hoses are clear, the coolant is perfectly clean, and there's no gas escaping or bubbling in the expansion tank, no water in the engine oil, and no water vapor from the exhaust. Therefore, the remaining possibilities are a) the water pump and b) a hidden crack on the outside of the cylinder head, where the water is not visible on the hot engine block because it evaporates too quickly.
Since the timing belt needs to be replaced anyway, we'll also go ahead and replace the water pump.
I will report on how things progress.
Okay, and any other previous modifications to the device:
The ESP (Exhaust Gas Recirculation) system has been re-sealed with Viton gaskets, but after the switch back from alternative fuel to diesel, it started making terrible noises. Now I understand how the ESP works; it's a masterpiece of fine mechanics. I installed a control cone for higher boost pressure, but it doesn't help because the turbocharger is starting to fail and isn't producing more than 0.5 bar of boost. I have a spare one lying around; if I decide to rebuild the cylinder head, I'll need to replace it.
Additional supply and return lines for the oil-fired heating system (10mm/8mm) were installed in preparation for a radiator tank, a heated oil filter, and the installation of SIRAI control valves. However, they are still lying around because diesel became so cheap that the work wasn't worth it, and then I ran out of time.
"My experience with PÖL was very positive. In winter, I simply added up to 50% PÖL to the diesel. Of course, I had new (standard, not the long ones) glow plugs installed, as well as refurbished injectors with a pressure of 145 bar and altered injection timing. The engine ran better with PÖL than with diesel. Reaching 180 km/h (actual speed according to GPS) on long distances was no problem, and climbing long hills at 140-150 km/h was effortless. With a more moderate driving style, I achieved 6-6.2 liters per 100 km, and even when driving at full throttle, I never exceeded 7.2-7.5 liters per 100 km."
Translated on 23-10-2026, 14:57.
LaurenzBo
Post24-11-2014, 11:54    Subject: Try it again! Quote
Replaced the water pump and timing belt. During the process, I discovered the following leaks:
- Water pump reservoir: It was leaking there. This was likely the reason why the cooling water requirement was very low during highway driving at 120-130 km/h, but significantly higher for short trips with constantly changing engine speed (approximately four times higher, 1.5 liters for 25 km). Presumably, the oil seal was reasonably tight with constant water pressure and engine speed, but leaked heavily when the pressure was constantly fluctuating.
- There's a hose connection on the water pump that leads to the oil cooler. It's very well hidden, and the hose was quite worn. I'm not sure if it was leaking there, but I installed a new hose clamp instead of the original type, and I applied a thin layer of sealant (Neofermit) to the fitting. I've had good experiences with that product.
- Tested the new thermostat, it starts a bit late (just before boiling, around 90-95°), but it works.
Der Zahnriemen sah zwar zunächst passabel aus, hatte aber am Kurbelwellenrad in der engen Krümmung schon Ablösungserscheinungen zwischen Gewebelage und Zähnelage. War It was long overdue.
"And the engine is running. The thermostat is working properly now, and I can heat up again. And there's no more coolant leak. So, it seems there's no crack in the cylinder head or leak in the head gasket, probably just lucky. The camshaft also looked very clean, with no signs of wear on the lobes."
I can't understand why the thermostat never opened with the old water pump. The only thing that comes to mind is that the old water pump had a plastic impeller. While it was firmly attached to the shaft, perhaps it was only secure when cold? If the plastic expands more in hot water, maybe it started to slip?
Now, all that's left is the problem with the engine not starting easily when it's cold. I suspect carbon buildup on the exhaust valves, so I'm going to add some fuel system cleaner to the diesel when the tank is almost empty and run it through the engine to clean it out. That has helped in the past, bringing the compression from 21 bar to 34 bar on a particular engine. I was too lazy to check it yesterday.
So, let's hope for the best, that the worst is over and that the engine doesn't give out on me prematurely.
Translated on 23-10-2026, 15:04.
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil pressure BSS Diesel Engine Technology
No new posts Oil pressure question for V6 engine, MKB: AKN Diesel Engine Technology
No new posts Oil Pressure Sensor 1.6L CAYC Diesel Engine Technology
No new posts Oil Pressure & Boost Gauge: Monitor Performance Diesel Engine Technology
