Is the entire driver's side door electrics not working on the Touran?
AA-K4
Post12-11-2014, 13:48    Subject: Is the entire driver's side door electrics not working on the Touran? Quote
Hello!
There is no communication with the central locking system, no communication with the window control module, no communication with the mirror control module, and no communication with the door control module!
Post12-11-2014, 14:12    Subject: Is the entire driver's side door electrics not working on the Touran? Quote
First, check all the fuses and the wiring harness, specifically between the A-pillar and the door. Also, the connector on the A-pillar as well.
Possibly, there is a cable break inside the bellows.
Post12-11-2014, 14:24    Subject: Is the entire driver's side door electrics not working on the Touran? Quote
If one is concerned about...
and specifically between the A-pillar and the door.
at
there is no zv
is amazed.
The door can be opened with the key icon_smile.gif.
AA-K4
Post12-11-2014, 15:00    Subject: Is the entire driver's side door electrics not working on the Touran? Quote
Okay!
Okay, I'll take a look at the wiring harness! The fuses are okay!
Thanks a lot!
GOLF4 V6 4MOTION HGP BI-TURBO
A4 8H 2,5 TDI
No new posts Touran GRA not working after TCU replacement Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L bis KW 04/2002, Radio schaltet nicht mehr ein Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran 1T - does not start, No 15 terminal Diesel Engine Technology
No new posts Driver's door won't open Transmission, Chassis, Body & Interior
No new posts Tür geht nicht mehr auf - Hilfe! Transmission, Chassis, Body & Interior
No new posts Schiebedach geht nicht mehr zu !!! Transmission, Chassis, Body & Interior
