michael978 Guest
10-01-2015, 22:15 Subject: TDI Ibiza: BPX Knocking Noise - Causes & Fixes |
Hello.
As the title states, I'm having a problem with a BPX.
The hydraulic components were making noises and were replaced for that reason.
However, with the new Hydros, it now rattles again after just a few minutes of running smoothly.
The engine has now been driven for 240,000 km, and it turns out that the last oil change was done 80,000 to 100,000 km ago.
I suspect the hydraulic components aren't getting enough oil because the channels are clogged with debris.
The oil filter could be removed in one piece and hasn't dissolved yet.
By the way, the rattling noise gets louder when the oil gets warm.
Do you think there's still hope for this engine, or is it better not to put any more effort into it?
Thank you in advance for your support.
Michael.
Translated on 17-09-2026, 18:45.
mullemaus Guest
10-01-2015, 23:34 Subject: TDI Ibiza: BPX Knocking Noise - Causes & Fixes |
If you suspect that the oil channels, etc., are blocked, then shorten the interval. And importantly, also measure the oil pressure sometimes.
What is the current oil viscosity?
Translated on 17-09-2026, 18:47.
michael978 Guest
11-01-2015, 1:57 Subject: TDI Ibiza: BPX Knocking Noise - Causes & Fixes |
Currently, it is filled with 5w30 oil. The oil pressure has been measured and is approximately 5 bar.
Steffen G Profi-Schrauber
Joined: 10/26/2006 Posts: 2560 Karma: +590 / -0 Location: bei Zwickau
11-01-2015, 2:30 Subject: TDI Ibiza: BPX Knocking Noise - Causes & Fixes |
Hi!
That's quite a lot of miles (100,000 km) to drive without an oil change.
But 5 bar of oil pressure is quite a lot.
Under what conditions did you measure the 5 bar pressure?
Engine cold, engine warm, idle speed, high RPM?
Normally, as far as I know, it's measured with a warm engine at idle speed, and then again at 2000 RPM.
There are also target values for that.
Okay, I don't know the values.
"But in my Corrado, the pressure relief valve in the oil pump was once stuck, which was a common problem with the VR6 engines."
However, that caused other problems.
Perhaps someone knows the target values for oil pressure under specific conditions?
What did the camshafts look like? Grüße, Steffen!
Translated on 17-09-2026, 18:48.
Herbert Profi-Schrauber
11-01-2015, 10:19 Subject: TDI Ibiza: BPX Knocking Noise - Causes & Fixes |
Mindestens 2 bar bei 2000 min-1 und ca. 80°C Öltemperatur. MMaximum value: 7 bar.
Does the oil meet the correct VW specification?
Herbert. Horch A4 8K CJCD
Translated on 17-09-2026, 18:50.
11-01-2015, 11:55 Subject: Ibiza 1.9 TDI: BPX Engine Noise/Rattling. |
michael978 wrote: | | The knocking gets louder when the oil gets warm. | AFAIK, this is a classic symptom of bearing damage in the crankshaft (cold = thicker oil dampens the impacts of worn bearings better -> the engine runs quieter).
Quote: | | Do you think there's still hope for this engine, or is it better not to make any further efforts? | As long as the performance is still acceptable, the oil consumption is normal, and an engine overhaul is financially feasible, I would say: it might be worth it. Gruß Ulf
Translated on 17-09-2026, 18:51.
Profile PM Garage |
11-01-2015, 12:30 Subject: TDI Ibiza: BPX Knocking Noise - Causes & Fixes |
Of course, damage from improper storage is also a possibility. I would simply check the hydraulic lifters: stop the "clattering" engine, and then check if any of the lifters have excessive play.
PS: Shouldn't the noise associated with bearing damage change depending on the load? Horch A4 8K CJCD
Translated on 17-09-2026, 18:52.
Autoservice Profi-Schrauber
11-01-2015, 18:02 Subject: TDI Ibiza: BPX Knocking Noise - Causes & Fixes |
Are the sealing plugs for the rocker arm shaft still in place? If not, the oil pressure in the transmission will decrease. LG, Onkel BM
