Passat 3BG BDH Engine: Check Engine Light/Limp Mode
audiavus
1992 Audi 100
Registered VCDS User
Post06-01-2015, 20:16    Subject: Passat 3BG BDH Engine: Check Engine Light/Limp Mode Quote
Hello everyone,
My father's V6 TDI engine is having problems.
Suddenly, while driving, a loss of power occurred, the check engine light illuminated, and the message "Emission system fault" appeared on the driver information system, followed by the engine entering limp mode.
The error memory displayed the following:
Exhaust gas recirculation: Control limit exceeded, maximum value.
Intake manifold pressure: Regulation limit exceeded.
I then removed the AGR valve, and it looks clean and is working properly. The diaphragm in the pressure sensor is also fine.
What was also noticeable was that when the engine was revved up, there was a brief, rather rough diesel-like sound, which I couldn't identify.
What can trigger an intake manifold pressure error?
Sommer: 1992er Audi 100 typ C4 mit 2,5L 7A Motor - Der Einzigartige
Winter: 1991er Audi 100 typ C4 mit AAR Motor
Schönwetter: 1990er Audi Coupe Quattro Perlmuttweiß mit 7A Motor
Translated on 17-10-2026, 14:41.
Karma: +807 / -0   Thank you, like it!
Post06-01-2015, 20:26    Subject: Passat 3BG BDH Engine: Check Engine Light/Limp Mode Quote
Please initiate an automatic scan.
Translated on 17-10-2026, 14:42.
audiavus
1992 Audi 100
Post06-01-2015, 20:34    Subject: Passat 3BG BDH Engine: Check Engine Light/Limp Mode Quote
I also tried that, but it only showed the driver's side crash sensor in addition to the other information, which I was already aware of. icon_sad.gif
mullemaus
Post06-01-2015, 21:25    Subject: Passat 3BG BDH Engine: Check Engine Light/Limp Mode Quote
You shouldn't 'try' it, you should actually do it and upload it. icon_lol.gif icon_wink.gif
Translated on 17-10-2026, 14:43.
audiavus
1992 Audi 100
Post07-01-2015, 13:43    Subject: Passat 3BG BDH Engine: Check Engine Light/Limp Mode Quote
Here's the log, I'm curious to see what it says...
Log-WVWZZZ3BZ4E340993-168720km.txt
 File name:  Log-WVWZZZ3BZ4E340993-168720km.txt
 File size:  4.63 KB
 Downloaded:  949 times
mullemaus
Post07-01-2015, 14:43    Subject: Passat 3BG BDH Engine: Check Engine Light/Limp Mode Quote
Another thing that was noticeable: when the engine revs up, there's a brief, rather rough diesel-like sound, which I couldn't identify.
Aggressive hammering? Are you dynamically checking the injection start?
audiavus
1992 Audi 100
Post07-01-2015, 14:50    Subject: Passat 3BG BDH Engine: Check Engine Light/Limp Mode Quote
Yep, that's kind of what it feels/sounds like.
Translated on 17-10-2026, 14:44.
audiavus
1992 Audi 100
Post08-01-2015, 17:49    Subject: Passat 3BG BDH Engine: Check Engine Light/Limp Mode Quote
Are there no "standard defects" that could explain the problems/errors I'm experiencing?
mullemaus
Post08-01-2015, 20:26    Subject: Passat 3BG BDH Engine: Check Engine Light/Limp Mode Quote
Well, maybe the icon_wink.gif spray nozzle.
audiavus
1992 Audi 100
Post08-01-2015, 21:33    Subject: Passat 3BG BDH Engine: Check Engine Light/Limp Mode Quote
I don't understand what the intake manifold pressure has to do with it.
How can I check this? Maybe check the start of the injection?
What was also noticed is that, according to the data displayed below, the boost pressure is always too low at lower engine speeds; it only reaches the target range at around 3000 RPM.
Translated on 17-10-2026, 14:45.
Post09-01-2015, 12:12    Subject: Passat 3BG BDH Engine: Check Engine Light/Limp Mode Quote
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post09-01-2015, 16:24    Subject: Passat 3BG BDH Engine: Check Engine Light/Limp Mode Quote
You can check the injection settings in the basic settings.
Not enough fuel, insufficient/delayed boost pressure = no power.
Check the control unit on the pump, as the VP 44 is known to have issues.
Greetings.
Translated on 17-10-2026, 14:46.
audiavus
1992 Audi 100
Post10-01-2015, 14:19    Subject: Passat 3BG BDH Engine: Check Engine Light/Limp Mode Quote
Thank you for the tip.
I just checked the VTG (Vehicle Traction Gauge) readings, and they are working perfectly.
However, I think I now know the real reason for the intake manifold control error: My father has that awful tuning box (which was sold to him by a so-called "friendly" dealer), and I completely forgot about it icon_redface.gif.
No wonder, then, that "too little" boost pressure appears in the measurement block icon_mad.gif.
Today, the car started normally at first, I drove it for about half an hour, then the limp mode came back, along with the emissions warning and the check engine light. I then logged the activity of the EGR valve, and sure enough: it's sticking occasionally! So, I'll start by checking the vacuum hose and the solenoid valve, and the electrical connection, and then I'll take a closer look at the valve itself.
Translated on 17-10-2026, 14:47.
No new posts Airbag Warning Light: VW Passat B5 A2 (2003) Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Emergency Start 1.9 TDI MBK AVF VW Passat 3BG On-Board Diagnostics (OBD)
No new posts ESP warning light is on. Audi A6 2.5 TDI AKE 132kW, 2003 On-Board Diagnostics (OBD)
No new posts Passat 1.9 TDI emergency mode while driving uphill with a... Diesel Engine Technology
No new posts VW Passat: Intermittent Limp Mode Issue Diesel Engine Technology
