Removing the rocker arm assembly from a 2.0 TDI engine.
KvD
Post30-01-2015, 17:22    Subject: Removing the rocker arm assembly from a 2.0 TDI engine. Quote
I'm relatively new to this forum, and I have a question that I can't find the answer to through a Google search:
Sure, please provide the text you would like me to translate from German to English.
2.0 TDI BKD, the timing belt had corrosion icon_sad.gif.
Now, the cylinder head, piston, connecting rod, and corresponding bearings need to be replaced.
Unfortunately, I'm having trouble disassembling the swingarm pivot. Is there a trick to it, or do you need special tools?
Morten.
 File size:  96.76 KB
 Viewed:  1157 times
 File size:  70.32 KB
 Viewed:  863 times
Post31-01-2015, 12:31    Subject: Removing the rocker arm assembly from a 2.0 TDI engine. Quote
Unfortunately, I'm now running into problems expanding the rocker arm axle. Is there a trick to it, or do you need special tools?
Possibly, she's just lost. Are the screws loosened evenly?
DomBay
Post06-02-2015, 11:44    Subject: Subject: Re: Disassembling the rocker arm assembly on a 2.0 TDI engine. Quote
KvD wrote:
Unfortunately, I'm now running into problems expanding the rocker arm shaft; is there a trick to it, or is specialized tooling required?
It's only 5 screws...
By the way: Interesting exhaust pipe. icon_biggrin.gif
wingmaster
Avatar-wingmaster
Post07-02-2015, 21:10    Subject: Removing the rocker arm assembly from a 2.0 TDI engine. Quote
That question can't be serious. You can see the five 10-tooth screws, right? Just unscrew them and remove the shaft. Possibly, tap it gently with a rubber mallet once or twice, as it can easily get stuck.
No new posts Remove Mirror Cover: How-to Guide Transmission, Chassis, Body & Interior
No new posts Golf II Tie Rod Removal: Steering Gear Guide Transmission, Chassis, Body & Interior
No new posts Bora Tailgate Trim Removal: Guide & Instructions Transmission, Chassis, Body & Interior
No new posts Golf III TDI: Remove Underbody Panel Diesel Engine Technology
