Jens 16syncro
17-03-2015, 14:59 Subject: Convert ESP Regulator to Universal Speed Controller |
If one wants to convert an old swirl chamber diesel engine for stationary use, a universal speed controller in the ECU would be highly desirable.
Can you easily retrofit an ESP (e.g., from a Golf 1.6D)? VW also offered this engine as an industrial engine, so there must be something available from Bosch.
Translated on 30-10-2026, 7:21.
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
17-03-2015, 22:07 Subject: Convert ESP Regulator to Universal Speed Controller |
This is called speed control via centrifugal force. Unfortunately, I don't know the Bosch part number for an ESP system like that.
NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 30-10-2026, 7:22.
Profile PM Email Garage |
vwSchrauber Profi-Schrauber
20-03-2015, 8:32 Subject: Convert ESP Regulator to Universal Speed Controller |
Okay, that's possible... You can keep everything the same except:
- Adjustable shaft
- Spring clip
- Idling spring.
- Mounting bracket for idle spring.
Tip: Ask Uncle Edgar for the part number of a specific component from an industrial motor. Using the VW part number, you can also find the Bosch part number.
Using the Bosch part number, you can go to a (qualified) Bosch service center and order the corresponding parts.
However, be aware that the stiffness of the springs varies depending on the rated speed and control characteristics.
You can also take something from the agricultural and construction machinery sector, but again, caution is advised – there are different lengths for the adjustment shafts.
Translated on 30-10-2026, 7:23.
20-03-2015, 8:40 Subject: Convert ESP Regulator to Universal Speed Controller |
I took a picture of a parts catalog.
| Description: |
| File size: |
35.87 KB |
| Viewed: |
796 times |
Translated on 30-10-2026, 7:24.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1514 Karma: +649 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
01-04-2015, 8:22 Subject: Convert ESP Regulator to Universal Speed Controller |
Profile PM Garage |
