Passat 3B Steering Column Problem: How Serious?
Alchard
Post15-05-2002, 17:03    Subject: Passat 3B Steering Column Problem: How Serious? Quote
Hello.
You're only away for a few weeks, and suddenly everything is turned upside down! Well, I guess I'll get used to it...
Okay, here's the translation:
'So, my problem is with my '98 Passat that has 150,000 km on it. A while ago, I started hearing a clunking noise in the front axle when driving on uneven surfaces. So, I took it to a local repair shop (which translates roughly to 'Association of Poor Businessmen'), and their diagnosis was a broken stabilizer bar linkage. This is apparently a common problem, so I bought a new one and installed it, but the clunking didn't go away. Now, in addition to the clunking on the left side, there's also a squeaking noise on the right side when the suspension compresses. Today, I went back to the VAG dealership: their diagnosis was that the lower rear guide arm is squeaking on the right side, and both upper control arms are defective at the bearing on the left side.'
Wie dramatisch ist die Sache? Hat jemand schon mal die oberen Lenker getauscht? Spurvermessung nötig? Sollte am Wochenend nochmal nach München (2x300km), noch möglich oder 'fliegt ' wirklich 'das Rad weg' (Aussage d. Me(chanikers)?
Thank you in advance.
Alchard
Translated on 01-08-2026, 18:17.
Michael II
Post16-05-2002, 9:49    Subject: Passat 3B Steering Column Problem: How Serious? Quote
Have you tried contacting them through their goodwill policy? In the "Problems/Solutions" section, there's an article about Volkswagen's goodwill policy. It describes this exact problem with the 3B engine. Perhaps you might still qualify based on your mileage or the age of the vehicle?
Tschüss
Michael II
Translated on 01-08-2026, 18:19.
Alchard
Post16-05-2002, 19:33    Subject: Passat 3B Steering Column Problem: How Serious? Quote
Hello.
What about the goodwill policy when you install the parts yourself? In the case of the stabilizer link, it was just stated that it costs around 100 euros, and there was no mention of any goodwill at that time. When they showed me the part, which can actually be replaced in a few minutes, I said I would install it myself (which still cost 30 euros). I have someone who can get me the parts for about 25% cheaper (which is still around 220 euros, if their diagnosis is correct).
Alchard
Translated on 01-08-2026, 18:20.
Michael II
Post16-05-2002, 21:10    Subject: Passat 3B Steering Column Problem: How Serious? Quote
In the article, the material and labor costs are listed separately.
You could talk to your mechanic about it sometime.
Tschüss
Michael II
Translated on 01-08-2026, 18:21.
No new posts Passat 2000: Sun Visor Light Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document MKB AKQ, defective timing belt tensioner Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adjusting Wiper Arm Stop Position with VCDS. Electrical Systems, Vehicle Electronics, Multimedia
No new posts A3 TDI: High Fuel Consumption - What to Do? Diesel Engine Technology
No new posts Mass Air Flow Sensor Problem: VW Passat Variant 2.5 TDI Diesel Engine Technology
No new posts Headlight Range Control Passat 3B Faulty Transmission, Chassis, Body & Interior
