eike Guest
06-05-2003, 9:47 Subject: Sticking Clutch Pedal: VW Golf G4 PD AXR Fix |
Hi everyone,
'During the winter months (during periods of freezing temperatures), we experienced a problem with the G4 PD74kW AXR model, manufactured in 12/01, where the clutch pedal would not return to its original position after repeated use. After each press, it would remain slightly lower, until eventually it was no longer possible to shift gears.'
The problem was simply resolved by manually pulling the pedal back up. Since then, it has been working perfectly again.
I've already found some information using the search function, but it seems to refer to older models.
Since the weather has been above freezing, the problem hasn't reappeared. However, the car is going to the workshop anyway, so they should take a look at it while they're there.
Does anyone else experience similar problems, and perhaps know the cause? Is it possible that moisture got in somewhere and froze?
Thank you for the information.
Eike.
Translated on 16-09-2026, 7:24.
donalexo Profi-Schrauber
Joined: 01/09/2003 Posts: 695 Karma: +0 / -0 Location: Würzburg
06-05-2003, 12:51 Subject: Sticking Clutch Pedal: VW Golf G4 PD AXR Fix |
Hello eike!
That sounds like there might be air in the hydraulic system to me. Doesn't the AXR have a hydraulically actuated clutch?
If bleeding the brakes doesn't work, then I suspect a faulty slave cylinder.
Actually, this quality issue should have been resolved by now within the Volkswagen Group. In my A3, manufactured in December 1996, I experienced this problem with the clutch slave cylinder, but it was replaced without any cost to me with an updated version.
What surprises me, however, is the connection with the low temperatures.
Alex. AUDI A3 1.9 TDI, EZ 12/96, ursprüglich MKB AGR, umgebaut zum AHF mit GT1749V-Lader, verkauft mit 250tkm
Touran 1.9 TDI, EZ 09/2004
Translated on 16-09-2026, 7:26.
Bertil Profi-Schrauber
06-05-2003, 13:24 Subject: Sticking Clutch Pedal: VW Golf G4 PD AXR Fix |
donalexo wrote: | Doesn't the AXR have a hydraulic clutch actuation system?
Yes, and not just him.
or the master cylinder...
Once the problem starts, it doesn't go away easily!
An extremely damaged AXR driver...  Gruß Bertil
Translated on 16-09-2026, 7:28.
JET Guest
06-05-2003, 19:19 Subject: Sticking Clutch Pedal: VW Golf G4 PD AXR Fix |
It was the clutch master cylinder for me.
Translated on 16-09-2026, 7:29.
