Audi A3 Whistle Noise: BLS Engine, 2006
chli1976
Post17-04-2015, 14:26    Subject: Audi A3 Whistle Noise: BLS Engine, 2006 Quote
I'm hearing a whistling noise on my BLS. I thought it might be coming from the AGR cooler, specifically where the shaft is for the switching mechanism, and that it might be a leak. However, when I hold my hand there, I don't feel anything.
"When the engine is idling, you can barely hear anything. If you disconnect the EGR valve, you can hear it even at idle. Of course, you can also hear it when you accelerate. When driving and the turbocharger is under more load, the noise becomes much, much louder."
I then checked the intake side of the turbocharger, but there was no axial play, and I didn't see any signs of wear or scoring.
I'm not 100% sure if the noise is actually coming from the turbo, and replacing it based on suspicion is a bit expensive. I also found a technical service bulletin (TPI) where the exhaust hanger (device carrier) is changed from metal to plastic to address whistling noises.
Does anyone recognize this sound?
Audi A3 Whistle Noise: BLS Engine, 2006 - 20150417_144242[2].mp4
 Pfeifgeräusch BLS Motor
 File size:  2.69 MB
 Viewed:  641 times
VCDS
Translated on 06-09-2026, 1:46.
Post17-04-2015, 14:31    Subject: Audi A3 Whistle Noise: BLS Engine, 2006 Quote
Your video is gone?!?
I also found a technical information bulletin where the material of the exhaust bracket (device carrier) is changed from metal to plastic to eliminate whistling noises.
What TPI?
Do you have it?
Part numbers for the replaced parts?
Greetings.
Translated on 06-09-2026, 1:47.
chli1976
Post17-04-2015, 14:37    Subject: Audi A3 Whistle Noise: BLS Engine, 2006 Quote
2012959/3
1K0 253 144 BC
VCDS
Translated on 06-09-2026, 1:48.
Post18-04-2015, 20:21    Subject: Audi A3 Whistle Noise: BLS Engine, 2006 Quote
chli1976 wrote:
1K0 253 144 BC
Based on the description, I suspected that was the part.
But what about the __WHISTLE__?
How does that work?
I'm now more inclined to suspect that the noise is coming from the BLS (Blockheizkraftwerk/Combined Heat and Power unit) and I'll just replace it to see if that fixes it.
No new posts Doku Lupo 6X1 MJ 2001, Whistling noise at the doors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8PA 2.0 TDI BMM / 03/2006 / Control Modules 3.8, ... Upload
No new posts Fault: Remote control for Audi A4, model year 2006. On-Board Diagnostics (OBD)
No new posts Audi 4F 3.0 TDI 2006, Air conditioning faulty ( 02071 / 0... Transmission, Chassis, Body & Interior
No new posts GTI 2.0 BWA whistling noise Gasoline Engine Technology
