Recommendation and Source: Underbody Protection
Post09-06-2015, 22:54    Subject: Recommendation and Source: Underbody Protection Quote
Recommendations for durable, effective, and also affordable underbody protection are welcome!
Currently, I am using a product from Landi, which is good for preservation, but is anything but winter-proof... therefore, a product based on wax would probably be a good idea. icon_question.gif
Best regards, Rainer
Karma: +590 / -0   Thank you, like it!
Post09-06-2015, 23:20    Subject: Recommendation and Source: Underbody Protection Quote
Hi!
Check out Elaskon UBS 2. It's water and winter resistant. Lasts for many years.
Warning: When used in warm weather, especially when dispensing from 1-liter cans using a pressure gun, it will create a mist, and you can end up saturating your entire car, including the windows and roof. Proper coverage is very important there.
We seem to have discussed this topic already twice. I usually lightly oil the rusted spots beforehand, as a kind of bonding agent.
Post10-06-2015, 10:10    Subject: Recommendation and Source: Underbody Protection Quote
Thanks for the tip!
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post10-06-2015, 10:21    Subject: Recommendation and Source: Underbody Protection Quote
I have had good experiences with the Innotec Hi-Temp Wax Spray.
http://www.innotec.at/web/produkte/produkt.php?id=176
It has excellent adhesion and is applied in a very thin layer.
Another advantage is that this product is available in brown and transparent.
The risk that rot would continue unnoticed under the underbody protection has thus been averted.
Unfortunately, it's not exactly cheap. The aerosol can costs approximately 14,-.
One or two for a complete treatment.
I always treat the underbody with Brunox spray at the rusty spots first. Apply it twice and then let it dry thoroughly. After that, spray on Hi-Temp Wax.
Another advantage is that the underbody or axle parts sprayed with it look very well-maintained afterwards.
The TÜV inspectors need to assess the overall condition of the vehicle, and they often look at the "big picture" to determine whether a car has been properly maintained and cared for. icon_wink.gif
Post10-06-2015, 15:23    Subject: Recommendation and Source: Underbody Protection Quote
We've had something like this before icon_wink.gif:
/viewtopic.php?t=24639&highlight=mike+sanders
Dry, the valley looks like the cavity protection from the Golf 2 era.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post11-06-2015, 20:19    Subject: Recommendation and Source: Underbody Protection Quote
I use LM Cable Lubricant. It adheres very well, is thick and viscous. Is it available in 5-liter containers, in the usual 1-liter cans for the compressor, and as a spray? The latter is only mentioned for completeness. The spray cans tend to clog. This is also understandable for the contents icon_smile.gif. However, processing the liter bottles with compressed air works perfectly. However, one must also remember, especially in areas with splashing water. I do this for my own cars once a year. Sometimes I also apply graphite oil first and then the cable lubricant. I have no problems with rust. And the salt is also deposited neatly every winter.
 File size:  26.76 KB
 Viewed:  665 times
 File size:  21.26 KB
 Viewed:  1541 times
Passat Variant BGW 2005
Steffen W
Post11-06-2015, 20:21    Subject: Recommendation and Source: Underbody Protection Quote
TN 1 Liter Bottle LM 6173 and Spray LM 6135.
Post11-06-2015, 21:17    Subject: Recommendation and Source: Underbody Protection Quote
No new posts PQ35 Underbody Protection Transmission, Chassis, Body & Interior
No new posts Audi A4 2008 8K Underbody protection / Stone chip protection Transmission, Chassis, Body & Interior
No new posts Battery charger recommendations Electrical Systems, Vehicle Electronics, Multimedia
No new posts TDI Kombi Empfehlung gesucht ! Diesel Engine Technology
