Golf 3 TD Airbag Control Unit - VAG COM 3.11
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
LaurenzBo
Post06-06-2015, 23:40    Subject: Golf 3 TD Airbag Control Unit - VAG COM 3.11 Quote
Hello, I'm experiencing the classic airbag warning light issue - the sensor under the passenger seat was briefly dislodged during cleaning, and now the airbag light is on.
Car: Golf 3 Variant TD, manufactured in 1998 (AAZ, 75 horsepower), ABS, Airbag, Exhaust gas recirculation.
On my old laptop, I still have VAG COM 3.11 and a USB Serial Adapter with FITS chip. However, I am unable to establish a connection with any control device, whether by plugging it in and starting it before turning on the ignition, or when the ignition is on, regardless of whether I use a baud rate of 9600 or 4800.
The adapter is found at COM2, and is listed as a USB-Serial adapter at COM2 in the Control Panel (Win XP). The LED indicates communication attempts from the VAG COM. Only, no response.
Does anyone know any old tricks?
DieselBär30x
Avatar-DieselBär30x
Post07-06-2015, 7:09    Subject: Golf 3 TD Airbag Control Unit - VAG COM 3.11 Quote
Hi!
Unfortunately, I do not have access to a Dieselschrauber diagnostic system, nor do I have a support key.
Prominently visible in the contribution window on the lower left icon_wink.gif
Best regards from Munich!
PS: Whoever has to disconnect their airbag while cleaning probably already had one on their plate icon_lol.gif
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-COM: Airbag Control Unit Diagnostics Diesel Engine Technology
No new posts Airbag Control Unit Transmission, Chassis, Body & Interior
No new posts Airbag control unit On-Board Diagnostics (OBD)
No new posts Airbag control unit, Passat 3B Gasoline Engine Technology
