Rotation angle after Z-axis inversion
Go to page: 1, 2, 3  Next
Post18-06-2015, 16:16    Subject: Rotation angle after Z-axis inversion Quote
Hi.
I just had my BMR serviced at the (Volkswagen) workshop.
Previously, with a warm engine idling, I had a crankshaft angle of 0.35°.
Code:
17:21:15 Block 004: Ansteuerung Pumpe-Düse Ventile
  801 /min  Motordrehzahl (G28)
  5.0 °n.OT  Förderbeginn (Sollwert)
  3.7°KW  Förderdauer (Sollwert)
  0.35°  Verdrehwinkel
Now, after the change (engine not yet fully warm, idling), it's 2.23°.
Code:
16:00:31 Block 004: Ansteuerung Pumpe-Düse Ventile
  800 /min  Motordrehzahl (G28)
  4.0°KW  Förderdauer (Sollwert)
  2.23°  Verdrehwinkel
Should I complain about this, or am I just being too picky?
Karma: +784 / -0   Thank you, like it!
Post18-06-2015, 16:29    Subject: Rotation angle after Z-axis inversion Quote
Wasn't there something about the direction (+/-) and the timing belt length?
I'm looking for a picture or diagram showing the timing belt routing during a timing belt replacement.
Post18-06-2015, 16:32    Subject: Rotation angle after Z-axis inversion Quote
Do you mean that the price is still going to increase?
And if so, does it continue to move towards 0.0?
Post18-06-2015, 16:35    Subject: Rotation angle after Z-axis inversion Quote
IMHO, it should be adjusted slightly later due to belt stretch and the position of the adjuster. +2°KW I would just leave it as is , but it's already trending towards being too late.
Here's something else about the rotation angle:
Post18-06-2015, 16:40    Subject: Rotation angle after Z-axis inversion Quote
I'm just seeing that the golf ball had a handicap of -2.5 before the change, and it was also working perfectly fine.
Post18-06-2015, 16:56    Subject: Rotation angle after Z-axis inversion Quote
Do you know the sign conventions?
For a 1.9 PD engine, positive values indicate a late ignition timing, which typically results in a high torque peak but a lower peak power output.
In a WOT (Wide Open Throttle) log, up to the maximum pressure (Pmax), the compression ratio increases, and the twist angle becomes increasingly "positive" with increasing engine speed.
If you don't already have a BMR log, you might want to get one done.
Post18-06-2015, 17:18    Subject: Rotation angle after Z-axis inversion Quote
Hm,
Damn, things are getting complicated.
Because I have two camshafts... and also two camshaft gears.
Post18-06-2015, 17:57    Subject: Rotation angle after Z-axis inversion Quote
With a northwest orientation?
Probably not, unless the suspected calibration errors are resolved...
Post18-06-2015, 19:44    Subject: Rotation angle after Z-axis inversion Quote
Do you know the sign convention?
For a 1.9 PD engine, positive values indicate a late NW (negative working stroke) adjustment, which typically results in a high torque peak but a lower peak power (Pmax).
Sure?
Post18-06-2015, 23:06    Subject: Rotation angle after Z-axis inversion Quote
For a 1.9 PD, positive values indicate a late northwest adjustment
That's how I remember it too. If the Northwest wind is lagging by 2.5°KW, it should likely lag even more over time. I believe 3° is probably at the limit of the acceptable tolerance.
"With the 1.9 engine, you could observe how the synchronization behaved when revving it up." Angle direction + moved...
So... personally, I would have that corrected.
Post19-06-2015, 1:22    Subject: Rotation angle after Z-axis inversion Quote
How is this actually corrected?
In the repair instructions for replacing the timing belt, the camshaft wheels are only temporarily fixed in place.
However, the NW gears have teeth on the opposite side of the hole to the locating hole.
Which one do you correct, both of them?
Please provide the text you would like me to translate from German to English.
Our 1.9 BLS engine had a compression ratio of -2.5 before the top ring replacement.
After that, -2.9..-3.4 (I just found that in my notes).
That was in October 2013... I need to check that now.
vwSchrauber
Karma: +42 / -0   Thank you, like it!
Post19-06-2015, 10:06    Subject: Rotation angle after Z-axis inversion Quote
Where is the Northwest position sensor located?
In my opinion, the relevant regulation for the behavior described by Ulf is the EinlassNW.
Post19-06-2015, 10:26    Subject: Rotation angle after Z-axis inversion Quote
dieselmartin wrote:
How is that actually corrected?
I have some elongated holes in the camshaft sprocket. /viewtopic.php?t=26285
I need to check the twist angle/synchronization angle on my setup. I think I intentionally set it slightly away from "zero" – if that was the wrong direction, that would be a problem...
Edit: Okay, it seems I was right after all, so "-" indicates early!
 File size:  151.04 KB
 Viewed:  5594 times
Post19-06-2015, 11:13    Subject: Rotation angle after Z-axis inversion Quote
Yes.
but:
Only the front, intake camshaft is being measured.
If I now loosen the long bolts, I will change the measured value in VCDS, specifically the timing of these camshafts. I can also check that using VCDS.
But what should I do with the camshaft lobe - it also has elongated holes, but I don't have any measurements for that.
How do I adjust the 0.7 degrees differently? Surely, no one can determine that with their eyes on the camshaft sprocket?
Post19-06-2015, 11:16    Subject: Rotation angle after Z-axis inversion Quote
But what should I do with the cam lobe - it also has elongated holes, but I don't have a measurement for that.
You adjust it so that, when the belts are installed, both camshafts can be locked in place. "The 'slots' actually secure the waves, not the wheels."
dieselschrauber wrote:
...So, when buying a timing belt kit, you can often find a crankshaft pulley timing pin included, which is often sold as a set with a matching dowel pin for the camshaft gears. Since you actually need 2 alignment pins, or it's advisable to use them, you can just as easily use a Torx screw of a similar diameter for the second camshaft gear...
Post19-06-2015, 11:19    Subject: Rotation angle after Z-axis inversion Quote
But what should I do with the eccentric cam - it also has elongated holes, but I don't have a measurement for that.
Best regards, Rainer
OK, thank you.
next question:
extra something placed next to "zero".
And how? "Especially, how exactly does that work?"
In the rep thread, you should push the bypass wheel backward/to the left.
So, did you press harder or softer?
No new posts Doku MKB ABC, schlechter Motorstart nach MSG-Wechsel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran GRA funktioniert nicht nach STG Wechsel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacement of injector nozzles/holders on a VP-TDI Troubleshooting & Guides
No new posts BMR unrund nach PPD Wechsel Diesel Engine Technology
No new posts Performance loss after ZR change On-Board Diagnostics (OBD)
No new posts AFN nach ZKD-Wechsel Leistungsverlust. Turbo? Diesel Engine Technology
No new posts AXR starker Leistungsverlust nach ZKD Wechsel Diesel Engine Technology
