LMM vs. BMR: Which is Better?
Go to page: 1, 2, 3, 4  Next
Post06-07-2015, 9:56    Subject: LMM vs. BMR: Which is Better? Quote
Does anyone have LMM values that I can compare to my BMR?
I suspect this component is nearing the end of its lifespan, but I want to somehow verify that with measurements and data.
I find it strange that it never exceeds 1000 mg/H (not logged, just observed).
However, I can no longer precisely remember the icon_sad.gif conditions.
Greetings.
EDIT: Unfortunately, my BLS has a different LMM icon_sad.gif.
Translated on 28-09-2026, 21:10.
Post06-07-2015, 10:36    Subject: LMM vs. BMR: Which is Better? Quote
For the 1.9 TDI engine, I would say: first, log the mass airflow sensor (MAF) data (MWB icon_cool.gif and check if the engine comes out of limp mode (limitation of power) safely across the entire RPM range when the lambda sensor is within the specified range.
It's only worth looking into the LMM if it's actually beneficial.
There are engines that calculate the opacity without using a mass airflow sensor (MAF), relying only on the lambda sensor (LD). And then, an aging MAF sensor can even reduce the carbon buildup in the intake manifold because it regulates a lower exhaust gas recirculation (EGR) rate. icon_twisted.gif
I don't know what it's like with BMR.
Translated on 28-09-2026, 21:11.
Post06-07-2015, 12:07    Subject: LMM vs. BMR: Which is Better? Quote
He just doesn't seem to get going sometimes.
It's not building boost properly and then gets stuck at a certain RPM when you try to accelerate.
My idea was that he should believe he wasn't getting enough air.
Translated on 28-09-2026, 21:13.
Post06-07-2015, 13:14    Subject: LMM vs. BMR: Which is Better? Quote
That could also be due to the LD regulation.
Post06-07-2015, 13:30    Subject: LMM vs. BMR: Which is Better? Quote
How can heat be sensitive?
Post06-07-2015, 13:40    Subject: LMM vs. BMR: Which is Better? Quote
Sure, here's the translation:
"For example, thanks to hot-clamping?"
Post06-07-2015, 15:16    Subject: LMM vs. BMR: Which is Better? Quote
The AGR is also a potential candidate.
Code:
003,0,Abgasrückführung
003,1,Motordrehzahl,(G28),Sollwert (Leerlauf): 790...810 U/min\nSollwert (Volllast): 2800...3200 U/min
003,2,Abgasrückführung,(Sollwert),Sollwert (Leerlauf): 200.0...350.0 mg/Hub\nSollwert (Volllast): 900.0...1300.0 mg/Hub
003,3,Abgasrückführung,(Istwert),Sollwert (Leerlauf): 180.0...350.0 mg/Hub\nSollwert (Volllast): 900.0...1300.0 mg/Hub
003,4,Ansteuerung,Abgasrückführung,Sollwert (Leerlauf): 20.0...70.0 %\nSollwert (Volllast): 0.0 %
B003,0,Abgasrückführung
; Zündung EIN, Motor EIN (im Leerlauf)
; Grundeinstellung aktivieren
; Bremspedal und Gaspedal gleichzeitig betätigen
; Abgasrückführung wird abwechselnd ein- und ausgeschaltet
; Differenz zwischen "AGR aktiv" und "AGR inaktiv" muss mindestens 100.0 mg/Hub betragen
Post06-07-2015, 17:09    Subject: LMM vs. BMR: Which is Better? Quote
Also, don't forget: With the current temperatures of 35°C+, a certain "chewing gum" effect when accelerating is also somewhat normal. icon_wink.gif
Translated on 28-09-2026, 21:14.
Post06-07-2015, 22:36    Subject: LMM vs. BMR: Which is Better? Quote
TDI-GTI-4-Motion wrote:
Don't forget: With the current temperatures of 35°C+, a certain "chewing gum" effect when accelerating is also somewhat normal. icon_wink.gif
Yes, especially when there's a heavy trailer attached and the air conditioning is running full blast, even the ARL sounds sluggish at 39º, almost as if it's missing, roughly estimated, 15 horsepower icon_rolleyes.gif. I have no idea how hot the LD was; I didn't have a laptop with me to check.
Post06-07-2015, 22:40    Subject: LMM vs. BMR: Which is Better? Quote
The intake air temperature was 50°C - at least, that's what it showed when I was driving on the highway.
I haven't looked closely at the Lambada regulation yet... and the 70% N75 should still be 100% VTG fabric.
The more surprising it is that, at 140 km/h in 6th gear (GRA), it doesn't achieve the boost pressure of 1800 mbar icon_eek.gif.
Translated on 28-09-2026, 21:16.
Post06-07-2015, 23:03    Subject: LMM vs. BMR: Which is Better? Quote
It's all the more strange that it doesn't achieve the 1800 mbar boost pressure in 6th gear (GRA) at 140 km/h icon_eek.gif
Why would he build up more boost pressure than necessary?
Post07-07-2015, 8:08    Subject: LMM vs. BMR: Which is Better? Quote
... he should earn more because he wants more.
He is clearly not reaching the target pressure.
 File size:  58.34 KB
 Viewed:  505 times
Translated on 28-09-2026, 21:17.
Post07-07-2015, 8:11    Subject: LMM vs. BMR: Which is Better? Quote
Well, it looks like there's a vacuum leak or the charger is stuck on the VTG...
Post07-07-2015, 8:21    Subject: LMM vs. BMR: Which is Better? Quote
What do you mean by "the charger is sticking out"?
I'm puzzled that he usually adjusted the settings perfectly in that system.
Even in that "state," the smoke level was still high enough.
The top 70% of the N75 should not have been opened, even by VTG.
Unfortunately, I didn't log the waypoint.
While driving, there were no noticeable issues; the car easily reached and maintained a speed of 140 km/h.
Here's an overview - I didn't notice the "boost pressure" error until later.
The log was self-driving... so I couldn't really think deeply or carefully about what I was doing icon_smile.gif. I just wanted to make use of the 150 km and the 36-38 degrees.
 File size:  83.87 KB
 Viewed:  513 times
LOG-01-008-011-067.CSV
 Hier die gesamten Daten zu den "Vorkommnissen"
 File name:  LOG-01-008-011-067.CSV
 File size:  152.8 KB
 Downloaded:  251 times
Translated on 28-09-2026, 21:18.
Post07-07-2015, 8:25    Subject: LMM vs. BMR: Which is Better? Quote
I made a typo above.
But unfortunately, I didn't log the waymarker.
It would be a good idea... icon_wink.gif However, I would first check all the vacuum hoses.
Translated on 28-09-2026, 21:20.
Post07-07-2015, 8:35    Subject: LMM vs. BMR: Which is Better? Quote
I received a similar log from a 2.0 CR TDI engine belonging to a friend. Like Rainer, I initially suspected a vacuum leak. By using a syringe on the VTG sensor, we were able to identify it as the cause... It's quite a quick check.
