White smoke and misfire on 2.0 TDI engine
Christopha3
Post07-07-2015, 9:25    Subject: White smoke and misfire on 2.0 TDI engine Quote
I'm having a problem with my 2.0 TDI CR 140PS CBBF engine. Occasionally, it takes a bit longer to start when the engine is cold, and then there's white smoke. This also happens while driving until the engine is somewhat warm. Very rarely, there's also a slight hesitation when accelerating gently at low RPMs.
It only occurs when the car has been parked for more than about 5 hours, and also at warmer temperatures (above icon_smile_thumb_up.gif5°C). The car has 58,000 km and was manufactured in 2010. It had a chip tuning modification approximately six months ago.
I'd like to read the injector values now. Can anyone explain to me how to do that exactly?
Thank you in advance!
Translated on 27-09-2026, 22:01.
Post07-07-2015, 10:15    Subject: White smoke and misfire on 2.0 TDI engine Quote
Can you tell what the white smoke smells like? You can usually distinguish between motor oil and diesel fuel quite well with your nose.
Is coolant consumed?
You can find the injector timing at different pressure levels in the long list of advanced measurement data.
Generally speaking, about CR injectors:
/viewtopic.php?t=26829&highlight=injectors+testing
/viewtopic.php?t=26307&highlight=injectors+testing
Translated on 27-09-2026, 22:03.
Christopha3
Post07-07-2015, 11:11    Subject: White smoke and misfire on 2.0 TDI engine Quote
It smells like diesel. Also, the coolant level isn't decreasing.
Thanks for the links, but do I need to do this with a warm or cold engine? Or with the engine turned off?
Translated on 27-09-2026, 22:04.
Post07-07-2015, 11:27    Subject: White smoke and misfire on 2.0 TDI engine Quote
The calibration times for the zero-quantity calibration are "historical" values, meaning they were determined during normal operation under specific environmental conditions. They should always be readable.
Depending on the type of timing deviation, even at the current operating point, i.e., while the engine is running.
Please also check the idle speed control values using VCDS.
Translated on 27-09-2026, 22:05.
Christopha3
Post07-07-2015, 13:27    Subject: White smoke and misfire on 2.0 TDI engine Quote
Are these the correct readings? The engine is cold. And where can I find the values for the idle speed control?
 File size:  50.97 KB
 Viewed:  1966 times
Post07-07-2015, 13:58    Subject: White smoke and misfire on 2.0 TDI engine Quote
Yes, that's correct! The "idle speed control" refers to the upper values of "fuel injection deviation."
It looks okay to me - I don't think the injectors have any issues.
"The problem with sporadic errors is that, without the actual error occurring, you wouldn't expect to see any unusual readings. You should save the measurement data (by clicking on the icon for the VCDS measurement list, located to the right of the VCDS program window) and try to re-check the values while the error is actively occurring."
Is the error memory empty?
Translated on 27-09-2026, 22:06.
Christopha3
Post07-07-2015, 14:09    Subject: White smoke and misfire on 2.0 TDI engine Quote
OK, thank you for the quick help!
Translated on 27-09-2026, 22:07.
No new posts Document, 2.5 l, 6-cylinder / Jerking/Hesitation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BPW Shaking on Audi A4 TDI: Causes & Fixes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku V6 TDI AKE/AYM - Jerking and Lack of Power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts V6 TDI BDH: Slight vibration after DK change. Diesel Engine Technology
No new posts Noch leichtes Ruckeln nach ESP-Tausch geblieben. (B4 mit 1Z) Diesel Engine Technology
No new posts Ganz leichtes Ruckeln zwischen 1200 und 2000U/min 96kW PD? Diesel Engine Technology
No new posts Weißrauch und Startschwierigkeiten Diesel Engine Technology
