Car Door Repair: After Inspection
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
haithamina
Post16-10-2015, 17:33    Subject: Car Door Repair: After Inspection Quote
I had a vehicle scan performed before the B8 was returned due to whistling noises on the driver's side door. Apparently, a seal on or even the mirror itself was replaced.
"After the handover, I've noted some errors in the scan. What do they mean? Are they related to the disassembly on the door? What should I do next: clear the errors and see if they reappear?"
By the way, nothing has been changed at the engine electronics/software station. This wasn't necessary even with the EA288/EU6 engines.
Thank you in advance, haithamina.
Friday, October 16, 2015, 17:43:52:28160
VCDS -- A Windows-based VAG/VAS emulator. Runs on Windows 8.1 x86.
VCDS Version: RKS 15.7.1.0
Data as of: 20150910.
Vehicle Identification Number: WVWZZZ3CZFE49**** License Plate:
Mileage: 14,900 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: 3C (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 18 19 2B 42 44 52 55 5F 69
Mileage: 14,900 km
01-Motor electronics -- Status: Error 0010.
03-Brake electronics -- Status: OK 0000
05-Access/Startup Report -- Status: Error 0010.
08-Climate Control/Heating Unit -- Status: Error 0010.
09-Central Electrical System -- Status: Error 0010.
Parking Assist 10 -- Status: OK 0000
13-meter distance rule -- Status: Error 0010.
15-Airbag -- Status: OK 0000
16-Wheel Steering Electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
18-Heater -- Status: OK 0000
19-pin diagnostic interface -- Status: Error 0010.
2B steering column lock. -- Status: Error 0010.
42-Door Electric Driver -- Status: Error 0010.
44-Steering Assist -- Status: OK 0000
52-door electric passenger door - Status: Error 0010.
55-Brightness adjustment. -- Status: OK 0000
5F-Information Selection. I -- Status: OK 0000
69 followers -- Status: OK 0000
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BÀume, und die BlÀtter rascheln leise. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen."
Address 01: Engine Control Module (J623-CRLB)
Label file: DRV\04L-907-309-V1.clb
Part number SW: 04L 906 026 AS, HW: 04L 907 309 R.
Component: R4 2.0L EDC H21 1147
Revision: B5H21---
Encoding: 0119001A04541D083000
Operating number: WSC 05311 115 00301
ASAM Dataset: EV_ECM20TDI01104L906026AS 001006
ROD: EV_ECM20TDI01104L906026AS.rod
VCID: 7BF2648DF28B60E608-802E
2 error codes found:
25011 - Door control unit, driver's side.
U0199 00 [032] - No communication.
Sporadic - unconfirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 6
Error frequency: 1
Mileage: 14,844 km
Date: 2015.10.13
Time: 08:37:09
27703 - Door control module, driver's side.
Error priority: 2
Error frequency: 1
Mileage: 14,844 km
Date: 2015.10.13
Time: 08:37:09
Readiness: 0 0 0 0 0
Address 03: Brake Electronics (J104)
Label file: 5Q0-907-379-IPB-V1.clb
Part number SW: 3Q0 907 379 Q, HW: 3Q0 907 379 F.
Component: ESC H42 0610
Revision: 00000000 Serial Number: 60865000004744
Encoding: 0FEC6A8F34290B750777060441CA49F0562CD0E0608292F11460F078C002
Operating number: WSC 00015 115 00001
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_SE37.rod
VCID: 4898CB41F3DDFB7ED5-801C
No error codes found.
Address 05: Access/Startup Authorization (J518)
Label file: DRV\5Q0-959-435.clb
Part number SW: 3Q0 959 435 Hardware number: 3Q0 959 435
Part number: VWKESSYMQB 023 0524
Revision: 00023000 Serial number: 0363675890
Encoding: 000F0F0603
ASAM Dataset: EV_KessyHellaMQBAB 004027
ROD: EV_KessyHellaMQBAB_SK48.rod
VCID: 77FA78BDCEA344866C-8022
"One error found:"
12687616 - Data bus, missing message.
U1121 00 [008] - -
Sporadically - confirmed - checked since last deletion.
Error priority: 6
Error frequency: 1
Lost Count: 96
Mileage: 14,844 km
Date: 2015.10.13
Time: 08:37:09
Address 08: Climate Control/Heating (J255)
Label file: 5G0-907-044.clb
Part number SW: 5G0 907 044 AM, Hardware: 5G0 907 044 AM.
Component: Climatronic
Part number: H03 1001
Revision: 00001K10
Encoding: 12020124204101012015500000101802
ASAM Dataset: EV_ACClimaBHBVW37X 004131
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 72EC49A9A5C121AE5B-8026
Slave 1:
"One error found:"
459021 - Data bus: missing message.
U1121 00 [008] - -
Error priority: 6
Error frequency: 1
Lost Count: 96
Mileage: 14,844 km
Date: 2015.10.13
Time: 08:37:14
Address 09: Central Electronics (J519)
Label file: 5Q0-937-08X-HV1.clb
Part number SW: 5Q0 937 086 BD, Hardware: 5Q0 937 086 BD.
Part: BCM PQ37BOSCH 028 0146
Revision: -------- Serial Number: 86581903152474
Encoding: 00D38A46C24102FF4BC44004001407281C80000000000000000000000000
ASAM Dataset: EV_BodyContrModul1UDSBosc 014004
ROD: EV_BCMBOSCH_AU37.rod
VCID: 7DF66A95EC9F6ED636-8028
Slave 1:
Subsystem 1 - Part number SW: 3G1 955 119 A, HW: 3G1 955 119, Label file: DRV\5QX-955-119-V1.CLB.
Component: WWS 150322 042 0607
Serial number: 150327175911
Encoding: 0E4DDD
Slave 2:
Subsystem 2 - Part number SW: 5Q0 955 547 A, HW: 5Q0 955 547 A, Label file: DRV\5Q0-955-547.CLB.
Part number: RLHS 037 0059.
Serial number: S2Y15M04D07H06M27S37.
Encoding: 90A8DD
Slave 3:
Subsystem 3 - Part number SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB, Part Number: H01 0032.
Serial number: 24 01 2015 00000349
Subsystem 7 - Part number SW: 3G0 963 345, HW: 3G0 963 345.
Component: SysNameFanLin 014 0101
Serial number: ESE0012918
Subsystem 8 - Part number SW: 3G0 963 345, HW: 3G0 963 345.
Component: SysNameFanLin 014 0101.
Serial number: ESE0016259
Subsystem 9 - Part number SW: 3G0 963 345, HW: 3G0 963 345.
Serial number: ESE0013604
Subsystem 10 - Part number SW: 3G0 963 345, HW: 3G0 963 345.
Serial number: ESE0016274
3 error codes found:
549909 - Data bus, missing message.
U1121 00 [008] - -
Error priority: 6
Error frequency: 1
Lost Count: 96
Mileage: 14,844 km
Date: 2015.10.13
Time: 08:37:14
551445 - Data bus, missing message.
U1121 00 [008] - -
Error priority: 6
Error frequency: 1
Lost Count: 96
Mileage: 14,844 km
Date: 2015.10.13
Time: 08:37:14
550420 - Received data bus error value.
U1123 00 [008] - -
Error priority: 6
Error frequency: 1
Lost Count: 96
Mileage: 14,844 km
Date: 2015.10.13
Time: 13:20:56
Address 10: Parking Assist 2 (J446) Label file: 5Q0-919-294.clb
Part number SW: 5Q0 919 294 H, HW: 5Q0 919 294 A.
Part: PARKING ASSIST 8K H03 0053
Revision: -------- Serial Number: 39391507802076
Encoding: 0071051101
Operating number: WSC 05311 115 00060
ASAM Dataset: EV_EPHVA18AU3700000 002026
ROD: EV_EPHVA18AU3700000_SK48.rod
VCID: 4088D361DBEDC33E1D-8014
Address 13: Distance Control (J428)
Label file: None.
Part number SW: 3Q0 907 572 A, Hardware: 3Q0 907 572 A.
Part number: ACC BOSCH MQB H04 0130.
Encoding: 2A40608910FFC428949C804C
ASAM Dataset: EV_ACCBOSCHVW48X 001007
ROD: EV_ACCBOSCHVW48X.rod
VCID: 33628CAD9A5B68A690-8066
"One error found:"
1086 - Data bus, missing message.
U1121 00 [008] - -
Error priority: 4
Error frequency: 1
Lost Count: 96
Mileage: 14,844 km
Date: 2015.10.13
Time: 08:37:10
Address 15: Airbag (J234)
Label file: 5Q0-959-655.clb
Part number SW: 3Q0 959 655 AF, HW: 3Q0 959 655 AF.
Part: Airbag VW20, Part Number: 012 0195.
Revision: -------- Serial Number: 003R2P5VRC9C
Encoding: 98FCC0C0008000005C5400CC000800000065
Operating number: WSC 05314 000 00001
ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
ROD: EV_AirbaVW20TS6VW48X_VW48.rod
VCID: 020C19699561112E4B-8056
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number: SW: ----------- HW: 454 002 203 15
Component: SideSensor_Df 008 0887
Serial number: 3576U000000799D8731M
Encoding: 2D2D2D
Crash sensor for side airbag, passenger side.
Subsystem 2 - Part number: SW: ----------- HW: 454 002 203 15
Component: SideSensor_Pf 008 0887
Serial number: 3586U000000D69D8731Q
Encoding: 2D2D2D
Crash sensor for rear side airbag, driver's side.
Subsystem 3 - Part number: SW: ----------- HW: 454 802 403 15
Component: SideSensor_Dr 111 0148
Serial number: 3516RB2E249060000004
Encoding: 2D2D2D
Crash sensor for rear side airbag, passenger side.
Subsystem 4 - Part number: SW: ----------- HW: 454 802 503 15
Component: SideSensor_Pr 111 0148
Serial number: 3526R09ED4906000000C
Encoding: 2D2D2D
Crash sensor for front airbag, driver's side:
Subsystem 5 - Part number: SW: ----------- HW: 454 801 303 15
Component: FrontSensor_D, Part Number: 114 0149.
Serial number: 3556V06C3FF05000000K
Encoding: 2D2D2D
Address 16: Steering Wheel Electronics (J524)
Label file: DRV\5Q0-953-549.clb
Part number SW: 3Q0 953 521 P, HW: 5Q0 953 569 A.
Component: Steering module 075 0175.
Revision: FF032032 Serial number: 20150325401062
Encoding: 0400
ASAM Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 3D76AA95AC1FAED676-8068
Address 17: Control panel module (J285)
Label file: DRV\5G0-920-XXX-17.clb
Part number SW: 3G0 920 751 Hardware: 3G0 920 751
Part: COMBINATION INSTRUMENT 308 4311
Encoding: 07A409102F80000800882A001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009043
ROD: EV_DashBoardVDDMQBAB_SK25.rod
VCID: 62CC39E97521B12E2B-8036
Address 18: Auxiliary Heater (J364)
Label file: DRV\5Q0-963-272.clb
Part number SW: 5Q0 963 272 C. Hardware: 5Q0 963 272 C.
Component: STH-MQB 006 0069
Encoding: 9309
ASAM Dataset: EV_AuxilParkiHeateWOS 002014
ROD: EV_AuxilParkiHeateWOS_VW37.rod
VCID: 3664B5B989297D8EB7-8062
Subsystem 1 - Part number SW: 5Q0 963 513, HW: 5Q0 963 513.
Component: R149 T91-LIN 003 0301
Serial number: 00000000000001108881
Address 19: Diagnostic Interface (J533)
Label file: DRV\5Q0-907-530-V1.clb
Part number SW: 5Q0 907 530 AC
Part number HW: 5Q0 907 530 M
Component: GW MQB High, Part Number: 212 2203.
Revision: -------- Serial Number: 25031510802333
Encoding: 0B0300344F017300EF000258080F00010001070000000000000000000000
ASAM Dataset: EV_GatewConti 011020
ROD: EV_GatewConti.rod
Generator:
Control unit for multifunction device:
Subsystem 2 - Part number SW: 5G0 959 442 K, HW: 5G0 959 442 K.
Component: E221__MFL-DC1 H16 0040
Serial number: 38150000019460065132.
Encoding: 2CFFFF
Battery monitoring control unit:
Subsystem 3 - Part number SW: 3Q0 915 181 A, HW: 3Q0 915 181 A.
Part: J367-BDM, Hella, H04 8050.
Serial number: 0758495903
Inverter for wall outlet:
Subsystem 4 - Part number SW: 5Q0 907 155 C, HW: 5Q0 907 155 C.
Component: RECTIFIER H54 0033
Serial number: 0054833
Subsystem 5 - Part number SW: 3G0 919 204 C, HW: 3G0 919 204 C.
Component: Analog clock 209 2002.
"One error found:"
131658 - Door control module, driver's side.
U0199 00 [008] - No communication.
Error priority: 2
Error frequency: 3.
Lost Count: 96
Mileage: 14,844 km
Date: 2015.10.13
Time: 08:28:44
Address 2B: Steering column lock. (J764)
Label file: DRV\5Q0-905-861.clb
Part number SW: 3Q0 905 861 Hardware: 3Q0 905 861
Component: ELV-MQBB H05 0031
Serial number: 15000057321010
Encoding: 0000000000000000
ASAM Dataset: EV_ELVMarquMQBB 001007
ROD: EV_ELVMarquMQBB.rod
VCID: 71EE46A5A0C71AB6A2-8024
"One error found:"
12664832 - Data bus, missing message.
U1121 00 [008] - -
Error priority: 6
Error frequency: 1
Lost Count: 96
Mileage: 14,844 km
Date: 2015.10.13
Time: 08:28:42
Address 42: Door Electric Driver (J386)
Label file: 5QX-959-X93-42.clb
Part number SW: 5Q0 959 593 D. Part number HW: 5Q0 959 593 B.
Component: TSG FS 020 0028
Serial number: 280115BAR00153
Encoding: 003F0B208000020000001000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 428CD969D5E1D12E0B-8016
4 error codes found:
65604 - Door warning light.
B1326 01 [008] - Electrical fault.
Error priority: 3.
Error frequency: 3.
Lost Count: 97
Mileage: 14,844 km
Date: 2015.10.13
Time: 07:48:44
65608 - Lamp for ambient lighting of the speakers.
B13C8 01 [008] - Electrical fault.
Error priority: 3.
Error frequency: 4
Lost Count: 96
Mileage: 14,844 km
Date: 2015.10.13
Time: 13:22:36
65649 - Lamp for ambient lighting.
B1325 13 [008] - Interruption.
Error priority: 3.
Error frequency: 13
Lost Count: 97
Mileage: 14,844 km
Date: 2015.10.13
Time: 07:48:44
65650 - Turn signal light in the side mirror.
B11FD 13 [008] - Interruption.
Error priority: 3.
Error frequency: 1
Lost Count: 96
Mileage: 14,844 km
Date: 2015.10.13
Time: 08:38:59
Address 44: Steering Assist (J500)
Label file: DRV\5Q0-909-143.clb
Part number SW: 5Q0 909 143 K, HW: 5Q0 909 143 E.
Component: MQB_PP_APA 203 2033
Revision: 00000000 Serial Number: 0000187803
Encoding: 01000010005001
Operating number: WSC 00015 115 00301
ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
ROD: EV_SteerAssisVWBSMQBA_SK48.rod
VCID: 3B72A48DB20BA0E648-806E
Address 52: Power door lock, front passenger side (J387)
Label file: 5QX-959-X92-52.clb
Part number SW: 5Q0 959 592 D, HW: 5Q0 959 592 B.
Component: TSG BFS 020 0028
Serial number: 210315BCK02239
Encoding: 003F01208C00020000001000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 418ED665D0E7CA3612-8014
65570 - Functionality restriction due to missing message.
U1111 00 [008] - -
Error priority: 6
Error frequency: 1
Lost Count: 96
Mileage: 14,844 km
Date: 2015.10.13
Time: 08:37:09
65572 - Local data bus.
U10BA 00 [008] - No communication.
Error priority: 6
Error frequency: 1
Lost Count: 96
Mileage: 14,844 km
Date: 2015.10.13
Time: 08:37:09
Address 55: Headlight range adjustment (J431) Label file: DRV\5Q0-907-357.clb
Part number SW: 5Q0 907 357, HW: 6R0 907 357 A.
Component: LWR-ECU 005 0080
Revision: -------- Serial Number: --------------
Encoding: 03DA000009000000
Operating number: WSC 05311 000 00001
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB_SE25.rod
VCID: 75E672B5D4AF36967E-8020
Address 5F: Information Selection. I (J794)
Label file: None.
Part number SW: 3Q0 035 820 Hardware: 3Q0 035 820
Component: MU-S-D-ER H11 0138
Serial number: VWZAZ2R0094041
Encoding: 02840200FF00000011111201000808001F0100840120010001
ASAM Dataset: EV_MUStd4CTSAT 001018
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 66C425F99909CD0EC7-8032
Media Player 1:
Subsystem 1 - Part number SW: 3G0 919 605, HW: 3G0 919 605.
Component: ABT_Std-2 H44 1017
Serial number: VWZ8Z9RD500MWU
Address 69: Trailer (J345) Label file: DRV\5Q0-907-383.clb
Part number SW: 5Q0 907 383 D, HW: 5Q0 907 383 D.
Component: Trailer H14 0137
Revision: 8A001001 Serial Number: 0362199547
Encoding: 0100000202000000
ASAM Dataset: EV_TrailFunctGener2Hella 001005
ROD: EV_TrailFunctGener2Hella_SE26.rod
VCID: 3878BB81833D8BFEA5-806C
End----------------------------(Duration: 05:13)-----------------------------
Translated on 14-10-2026, 17:59.
Post16-10-2015, 17:39    Subject: Car Door Repair: After Inspection Quote
"These errors are normal for loose connectors. I would clear them and hope that no loose connectors or damaged cables are the cause."
"Then the errors would reappear, and another disassembly would be necessary."
Translated on 14-10-2026, 18:00.
No new posts Cushion button repair General Tips
No new posts Bosch VP44 pump control unit repair Troubleshooting & Guides
No new posts Repair of oil pump drive for 2.0 PD TDIs with balance shafts Troubleshooting & Guides
No new posts AC Noisy After G65 Sensor Repair Transmission, Chassis, Body & Interior
No new posts Fuel and temperature gauge; worse after repair :-( Transmission, Chassis, Body & Interior
No new posts LMM repair Diesel Engine Technology
No new posts Repair of PD elements? Diesel Engine Technology
