pax Profi-Schrauber
2000 Volkswagen Passat Support
23-08-2015, 17:18 Subject: Candle image glow plugs |
I removed the glow plugs from my spare engine (PD TDI). Unfortunately, I can't find much information about glow plug deposits. What happened to the bottom glow plug? Is it related to coolant injection?
Bye.
peace
| Description: |
| File size: |
162.25 KB |
| Viewed: |
1172 times |
Translated on 13-07-2026, 17:09.
Profile PM Garage |
Autoservice Profi-Schrauber
Joined: 04/14/2012 Posts: 2130 Karma: +99 / -0 Location: Nähe Dßsseldorf
23-08-2015, 18:11 Subject: Candle image glow plugs |
Have you ever made the glow plug glow while the engine was disassembled? Perhaps that will answer your question.
*Nichts ist einfacher, als sich schwierig auszudrĂźcken......*
Translated on 13-07-2026, 17:10.
mullemaus Guest
23-08-2015, 18:33 Subject: Candle image glow plugs |
Have you ever made the GK glow while it's disassembled? Perhaps your question is already answered then.
Genau.
I bet that 2 or 3 of them don't glow at all, or they glow really badly. And the one that supposedly has water injection is the one that works best.
Translated on 13-07-2026, 17:11.
DieselBär30x Profi-Schrauber
Joined: 01/17/2008 Posts: 3560 Karma: +101 / -0 Location: MĂźnchen & Passau
23-08-2015, 18:36 Subject: Candle image glow plugs |
Hello everyone!
One more note outside of the question:
From GSK No. 1, the seat was not sealed  .
Please take a closer look at the sealing surface in the ZK (presumably referring to a component), as it appears to be damaged.
Best regards from Munich!
3. T5 1,9 TDI PD (AXC), BJ04 - nur Ărger!
pax Profi-Schrauber
23-08-2015, 19:14 Subject: Candle image glow plugs |
Okay, thanks. I'll try to ignite it next time.
Regarding the comment about a leaky valve seat, I have to admit I'm not knowledgeable about that - it seems the sealing is done with the cone at the bottom of the stem, between the thread and the glow plug tip, rather than with the thread itself? However, I also ran the engine several times with loose spark plugs. It's possible that some grime got lodged in there during those runs.
Bye.
peace
Translated on 13-07-2026, 17:13.
Profile PM Garage |
23-08-2015, 19:42 Subject: Candle image glow plugs |
Servus Paxi!
pax wrote: | | ...gedichtet wird wohl mit dem Konus unten am Schaft zwischen Gewinde und GlĂźhspitze und nicht mit dem Gewinde? ... |
Correct. A thread alone cannot provide a seal.
And you can clearly see that the candle has already burned down, especially at the base of the GSK (presumably a piece of equipment), where it is exposed/was exposed.
Translated on 13-07-2026, 17:14.
