No Connection to Control Unit After Update
Toshi
Post17-09-2015, 18:04    Subject: No Connection to Control Unit After Update Quote
I finally updated from version 12.12 to 15.7.1 after a long time, and also updated the firmware of my HEX+CAN device from version 1.92 to 1.94 during that process.
Since this update, I can no longer access the engine control unit on my Passat (2.8 VR6, manufactured in 1991, with a 2x2 connector). I still have access to the ABS module, but it no longer loads completely, and I'm also unable to read any error codes.
He connects the airbag without any problems and it also reads the data correctly.
I consider a defect in the control unit or the connector to be unlikely, as I have unrestricted access using our Gutmann tester.
Unfortunately, I uninstalled version 12.12 during the update process.
What could be a reason for this?
Translated on 27-07-2026, 3:40.
Back to top Profile PM Email
Post17-09-2015, 18:55    Subject: No Connection to Control Unit After Update Quote
Please pay attention to the bitrate of the K-line (e.g., 9513) that is briefly displayed in the top left corner of the VCDS window when establishing the connection. icon_smile.gif Please note down the values for some control units, especially those where it works. }
Translated on 27-07-2026, 3:42.
Toshi
Post18-09-2015, 11:02    Subject: No Connection to Control Unit After Update Quote
ABS seems to be working now.
B 9625 KW 8980
Airbag B 9675 KW 018A
Toshi
Post18-09-2015, 14:08    Subject: No Connection to Control Unit After Update Quote
Resolved, can be closed.
It was my fault; I used the wrong 2x2 adapter.
Translated on 27-07-2026, 3:43.
Post18-09-2015, 17:33    Subject: No Connection to Control Unit After Update Quote
Okay, thanks for the feedback!
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Off: No Gas Response? Troubleshooting Guide. Diesel Engine Technology
No new posts P1640 Error After Update: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Unable to save after update On-Board Diagnostics (OBD)
No new posts HEX-NET: No Wi-Fi connection On-Board Diagnostics (OBD)
