Cracking noise from rear axle, Audi A6 4F (Solution)
Post05-01-2010, 16:05    Subject: Cracking noise from rear axle, Audi A6 4F Quote
I have an Audi A6 4F here that occasionally makes a cracking noise from the rear axle when there's slight movement.
I couldn't detect any dislocated joints, but I didn't disassemble anything further.
Is that a well-known disease?
Cracking noise from rear axle, Audi A6 4F (Solution) - a6-4f-knacken-hinterachse.mp3
 Bei seitlichen Hin- und Herbewegen des Fahrzeugs (kräftig schütteln) am Radkasten knackt es sporadisch an der Hinterachse/Befestigung zum Rahmen.
 File size:  195.1 KB
 Viewed:  204 times
Translated on 21-07-2026, 20:15.
Post15-01-2016, 19:13    Subject: Cracking noise from rear axle, Audi A6 4F Quote
Solution: The spare tire was "stuck" in its compartment, the tire rubber was slightly rubbing against the bottom panel of the spare tire compartment, and it wasn't properly secured with screws.
Fixed by attaching felt pads (chair leg protectors) to the contact surfaces of the spare wheel or by flipping the tire over and tightening the screws.
Translated on 21-07-2026, 20:16.
Ratings - Cracking noise from rear axle, Audi A6 4F
No new posts Golf 1J Rear Axle Noises: Repair Manual (1997) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J, Clicking, Squeaking at the rear axle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K Rear Axle Noise (1998) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rear Axle Noise: Causes and Solutions Transmission, Chassis, Body & Interior
No new posts Audi RS3 8Y Rear Axle Access On-Board Diagnostics (OBD)
No new posts Sharan 7N: Valve Block Crack Repair Transmission, Chassis, Body & Interior
No new posts Front Axle Noise: Causes and Solutions Transmission, Chassis, Body & Interior
