Tightening Torque: 16V PD Camshaft
Search
Automotive Technical Articles
Bookmarks
Links
Garage
Books / Tools
FAQ, Legal Notice & Privacy
RSS Feed
Register
Login
DE
EN
IT
New Topic
Reply
Dieselschrauber - Index
Diesel Engine Technology
View previous topic
View next topic
Author
Message
vwSchrauber
04-12-2015, 13:31
Subject: Tightening Torque: 16V PD Camshaft
Quote
"What is the correct torque for tightening the nuts on the tilt lever shaft at the BKD engine? Autodata doesn't have this information, and given the shallow thread depth of the studs in the nuts, I don't want to take any risks."
Translated on 25-09-2026, 16:01.
Profile
PM
chli1976
04-12-2015, 14:19
Quote
Do you mean the locknuts for the adjustment screws of the PD elements?
30 Nm.
VCDS
Profile
PM
vwSchrauber
04-12-2015, 14:49
Quote
Hi, no, the M8 hex nuts for the rocker arm shaft are for a 16V engine.
Profile
PM
chli1976
04-12-2015, 14:58
Quote
Normally, there would be screws here, so he must have gotten a replacement head at some point. I've installed those before too.
The screws should be tightened to 20 Nm plus 90 degrees.
VCDS
Translated on 25-09-2026, 16:02.
Profile
PM
vwSchrauber
07-12-2015, 12:48
Quote
Normally, there are screws here, so he must have gotten a replacement head at some point; I've installed those before too.
Yes, that could be the case - they are actually studs.
I've now tightened it to 20 Nm + just under 90° (one piece into the plastic deformation range), and it seems to be holding.
Translated on 25-09-2026, 16:03.
Profile
PM
New Topic
Reply
View previous topic
View next topic
Topic
Forum
Camshaft, Pump-Nozzle, 4 Cylinder 8V compatible
Cylinder Head Bolt Torque Specs 1Z
Crankshaft bolt torque specification ALH G4
Torque Specs: Nozzle Tip Over-Molded Nuts (VEP ESD)
Select a forum
Diesel Motorentechnik
Benziner Motorentechnik
On-Board-Diagnose (OBD)
Dieselschrauber Bar
Allgemeine Tipps
KFZ-Technik-Artikel
Fehlersuche & Anleitungen
Technische Daten
Fachartikel
Weblogs
KFZ-Technik Quiz und Halden
Quiz
Upload
Schrotthalde
You
cannot
Kaufmann Automotive GmbH
Shop für Kfz-Diagnosegeräte
. Parse time: 0.089s
