Good evening.
I have an Audi A4 B5 from 1995. After I went shopping, the car wouldn't start, and the immobilizer light was illuminated.
The error message is shown below.
Six weeks ago, I already brought the vehicle in because the interior was wet due to a clogged and overflowing water tank.
It was drained and, so far, there have been no further problems.
The engine control unit is dry, and the connection to the interior is also dry.
I charged the battery overnight because it was running low.
I can clear the errors in both the MSTG and the WFS, and then the icon for the WFS also disappears. However, when I restart, the icon lights up again, and the errors reappear.
Does anyone have any suggestions on where I could look, or has the MSTG (presumably a specific organization or project) been discontinued?
Edit:
In MWB 1 of the WFS, all approvals are present, which means the WFS should be functioning. The key has been recognized, the MSTG response is available, and the start authorization has been granted.
VCDS Version: RKS 15.7.1. Runs on Windows XP x86.
Data as of: 20150914.
Tuesday, December 01, 2015, 19:49:11:58542
Vehicle type: 8D - Audi A4/S4/RS4 B5 (1995 > 2001)
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Mileage: 102,830 km
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um drauĂen zu sein."
Address 01: Engine Control Unit
Label file: DRV\058-907-557-ADP.lbl
Part number: 8D0 907 557 B.
Component: 1.6L R4/2V MOTR HS D07
Encoding: 04001
Operating number: WSC 00000
VCID: 2F6B2594EDF9E246F4-4B64
"One error found:"
17978 - Engine control unit locked.
P1570 - 35-00 -
Readiness: Not Available.
Address 03: Brake Electronics
Label file: DRV\4D0-907-379-ABS.lbl
Part number: 4D0 907 379 D
Component: ABS BOSCH 5, Part Number: 7402.
Operating number: BB 37402
VCID: 2F6B2594EDF9E246F4-515A
No error codes found.
Address 08: Climate Control/Heating. Label file: DRV\8L0-820-043-2D.lbl
Part number: 8L0 820 043 D
Component: A4 CLIMATE CONTROL SYSTEM - FULLY AUTOMATIC - D75
Encoding: 04160
Operating number: WSC 06325
VCID: 295FCB8CD31D8C762A-25B8
8 error codes found:
00603 - Actuator motor for footwell/defrost flap (V85)
41-10 - Blocked or Unstressed - Sporadically.
01274 - Actuator for pressure relief valve (V71).
00792 - Pressure switch for air conditioner (F129)
31-00 - Short circuit to ground / Interruption.
00532 - Power supply voltage.
07-00 - Signal too low.
01297 - Temperature sensor for footwell airflow (G192).
30-00 - Disconnection / Short circuit after positive terminal.
01296 - Sensor for exhaust temperature, center (G191).
01206 - Signal for ignition deactivation duration.
27-10 - implausible signal - sporadic.
01582 - Coolant temperature sensor signal.
Address 15: Airbag
Label file: DRV\8A0-959-655.lbl
Part number: 8A0 959 655 C
Component: Airbag, V, AUDI D00.
Encoding: 01022
Operating number: WSC 33977
VCID: 336329E401D1C6A690-5178
"One error found:"
07-10 - Signal too weak - Sporadic.
Address 17: Control panel module
Label file: DRV\8D0-919-0xx-17.lbl
Part number: 8D0 919 033 C.
Component: B5_COMBINATION_INSTRUMENT D02
Encoding: 00142
Operating number: WSC 06311
VCID: 2859CE88C817B57E35-4B00
Address 25: Immobilizer
Label file: DRV\4A0-953-234.lbl
Part number: 4A0 953 234.
Part number: IMMO AUZ9Z0S0212298 D76
Encoding: 00000
Operating number: WSC 76783.
VCID: 5FCB9554DDD932C604-5178
"One error found:"
01177 - Engine Control Unit.
65-10 - unauthorized - occasional.
End----------------------------(Duration: 04:44)-----------------------------
