Alfa 159 1.9 JTDM: Specs, Problems, Review
chli1976
Post11-12-2015, 9:25    Subject: Alfa 159 1.9 JTDM: Specs, Problems, Review Quote
Do we have an Alfa mechanic here?
I have a 2006 Fiat 159 1.9 JTDM with a DPF and I'm getting the error code P1206.
According to my information, there is supposed to be an update for the engine control unit to fix this issue.
Part number: 0281012144.
Software version: 377871.
Can anyone tell me if there's any new information on this?
"Thank you."
VCDS
Translated on 23-10-2026, 2:25.
Post11-12-2015, 10:44    Subject: Alfa 159 1.9 JTDM: Specs, Problems, Review Quote
P1206 is a manufacturer-specific error code. For Fiat, it indicates that the differential pressure across the diesel particulate filter is too high, meaning the filter is clogged.
As someone who doesn't own a Fiat, I would check the following:
- Mileage. Is the DPF simply clogged with too much ash?
- Function of the exhaust temperature sensors and coolant temperature in the engine control unit (malfunction prevents/hinders DPF regeneration).
- Is the differential pressure sensor working correctly?
- Function of the AGR valve (malfunction prevents/hinders DPF regeneration).
- Leaks in the charge air system (cause excessive soot buildup in the engine, which fills the DPF much too quickly).
- Oil consumption?
Regarding potential software issues, I can't offer any further details, but I would like to point out that the same software has worked perfectly well for a long time.
Translated on 23-10-2026, 2:27.
No new posts Semi-pro system review on Alfa On-Board Diagnostics (OBD)
No new posts Intermittent power issue, Alfa 156 2.4 JTD common rail, 1... Diesel Engine Technology
