High-Pressure Pump Timing: Why It Matters
KombiBlue
Post12-01-2016, 17:07    Subject: High-Pressure Pump Timing: Why It Matters Quote
Hello, I'm wondering why the high-pressure pump in a VW CR engine is also connected to the crankshaft and camshaft.
Shouldn't it actually not matter in which position the pump is? It only increases the pressure of the diesel fuel, which is then stored in the rail. The water pump isn't disconnected either.
So, can someone please enlighten me?
What have I misunderstood or misinterpreted here?
Thank you.
Ralf.
Gruss Ralf
Passat Var. 2.0 TDI 3/2009, 125kW, CBBB
Translated on 07-10-2026, 19:09.
Post12-01-2016, 17:19    Subject: High-Pressure Pump Timing: Why It Matters Quote
Hello Ralf,
The pressure in the high-pressure accumulator is not constant. I suspect that disconnecting the high-pressure pump is intended to better manage resonances in the fuel pressure.
The engine control unit can predict, based on a defined pump position, how the fuel pressure will change in advance.
Translated on 07-10-2026, 19:10.
Post12-01-2016, 21:31    Subject: High-Pressure Pump Timing: Why It Matters Quote
dieselschrauber wrote:
Hello Ralf,
Best regards, Rainer
Translated on 07-10-2026, 19:11.
KombiBlue
Post13-01-2016, 16:16    Subject: High-Pressure Pump Timing: Why It Matters Quote
Yes, that makes sense.
Thank you, I now understand.
The HD isn't a centrifugal pump. I hadn't thought of that.
Great.
Ralf.
Gruss Ralf
Translated on 07-10-2026, 19:12.
vwSchrauber
Post15-01-2016, 8:34    Subject: High-Pressure Pump Timing: Why It Matters Quote
Bosch describes the "injection synchronization" feature in the CP4 documents, which in the passenger car sector is typically a single-piston pump that does not provide continuous fuel delivery.
For comparison: CP1, CP1H, CP2, and CP3, as well as various high-pressure pump systems based on common rail technology (Deutz), provide continuous fuel delivery.
KombiBlue
Post15-01-2016, 14:05    Subject: Pump Installation: Does Position Matter? Quote
So, does it not matter how the pump relates to the rest of the system?
And what type of fuel pump is in my Passat 2.0 TDI (CBBB)?
Thank you.
Ralf.
Gruss Ralf
Translated on 07-10-2026, 19:13.
vwSchrauber
Post18-01-2016, 10:02    Subject: High-Pressure Pump Timing: Why It Matters Quote
So, does it not matter how the pump relates to the rest?
Everything except the CP4 is actually irrelevant. Although, for example, with PSA, the high-pressure pump (CP3) is also disconnected, the synchronous operation is rendered unnecessary due to the 2/3 ratio.
And what kind of fuel pump is in my Passat 2.0 TDI (CBBB)?
If it's a Bosch system, the EU5 standard typically uses a CP4 injector. This applies to most other manufacturers as well.
I suspect that one of the reasons the five-cylinder engine disappeared from the Crafter is that it would have been too complicated to adapt it. Instead, they could simply use a similarly powerful four-cylinder engine from the "passenger car/van" lineup.
Translated on 07-10-2026, 19:15.
KombiBlue
Post21-01-2016, 6:19    Subject: High-Pressure Pump Timing: Why It Matters Quote
Okay, thank you, so CP4.
Do other people also experience so many problems with chip-generating HD pumps?
"Mine got it recently too. It's quite an expensive thing."
Thank you, Ralf.
Subject: Off-Topic: Why don't I receive emails when something is posted here?
Gruss Ralf
Translated on 07-10-2026, 19:16.
Post21-01-2016, 10:12    Subject: High-Pressure Pump Timing: Why It Matters Quote
KombiBlue wrote:
Do all other people also have so many problems with HD pumps that produce shavings?
Mine also experienced it recently as well.
It's quite an expensive ordeal.
What kind of engine do you have? What's the engine code?
OT: Why don't I receive an email when something is posted here?
It should work, have you checked the spam folder?
Translated on 07-10-2026, 19:17.
Post21-01-2016, 10:14    Subject: High-Pressure Pump Timing: Why It Matters Quote
According to the signature, a CBBB.
Translated on 07-10-2026, 19:18.
Post21-01-2016, 10:17    Subject: High-Pressure Pump Timing: Why It Matters Quote
Damn, I just thought that only the 3.0 TDIs of certain model years were affected.
@KombiBlueViewing profile: KombiBlue: What's the mileage and year of manufacture?
Post21-01-2016, 13:22    Subject: High-Pressure Pump Timing: Why It Matters Quote
If it's the one from the signature... from 2009.
Post21-01-2016, 14:08    Subject: High-Pressure Pump Timing: Why It Matters Quote
The mileage is still missing.
No new posts VP37 High-Pressure Pump Replacement Diesel Engine Technology
No new posts 2.0 TDI Timing Belt Replacement - High-Pressure Pump Misa... Diesel Engine Technology
No new posts Low rail pressure. - Defective high-pressure pump? Gasoline Engine Technology
No new posts Sharan G3: Specs, Features, and Reviews Diesel Engine Technology
