A3 Sportback: Retrofit Tow Hitch Installation
Go to page: 1, 2  Next
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post19-04-2015, 18:25    Subject: A3 Sportback: Retrofit Tow Hitch Installation Quote
Hello everyone,
I'm considering adding a detachable tow hitch to my A3. Which manufacturer would you recommend, especially regarding potential issues with the electrical connection? What should I be aware of?
pretzelman01
Translated on 09-10-2026, 22:35.
Post20-04-2015, 11:30    Subject: A3 Sportback: Retrofit Tow Hitch Installation Quote
I would have the Audi Original E-setting installed. That way, you're guaranteed to avoid any problems, and the mounting hardware will fit the vehicle best.
Translated on 09-10-2026, 22:36.
brezelmann01
Post20-04-2015, 17:23    Subject: A3 Sportback: Retrofit Tow Hitch Installation Quote
Wasn't there some manufacturer that used the same components as Audi/VW? I think I read something about that here before, but unfortunately, I can't find it anymore. icon_sad.gif
Post20-04-2015, 21:01    Subject: A3 Sportback: Retrofit Tow Hitch Installation Quote
My original VW tow hitch is from Westfalia - if that's what you meant.
Translated on 09-10-2026, 22:37.
brezelmann01
Post23-04-2015, 19:23    Subject: A3 Sportback: Retrofit Tow Hitch Installation Quote
You're welcome, Dieselmartin. I expressed myself poorly.
I actually wanted to ask which clutch manufacturer uses original VW/Audi control units. It seems that Westfalia is actually the one.
Post24-04-2015, 7:44    Subject: A3 Sportback: Retrofit Tow Hitch Installation Quote
Martin should make another statement on the matter.
Was ich weiß ist, dass Westfalia uses the same ECUs as VAG, but they have aftermarket software installed, which means they only behave like an original ECU in about 90% of cases.
Or am I mistaken?
Translated on 09-10-2026, 22:38.
Post24-04-2015, 11:25    Subject: A3 Sportback: Retrofit Tow Hitch Installation Quote
I was referring more to the "iron" aspect.
And yes, I believe the "software" is really like that:
- org STG also has "Westfalia" on it - but it identifies as "org VW"
EDIT:
- STG (1K0 ... E) is from Hella.
- Westfalia (it would be helpful to be more specific here) uses its own software on its own STGs (System Test Generators).
That's why I always buy 100% organic products, and I always recommend doing so.
Especially because of our mobile data centers (ESP, PDC... coffee machine, anything that behaves differently when something is connected).
Translated on 09-10-2026, 22:39.
Post24-04-2015, 11:57    Subject: A3 Sportback: Retrofit Tow Hitch Installation Quote
electric tailgate.
I've always had very good experiences with parts from salvage yards. They often have the original clutch (so far, I've only found Westfalia clutches, but that doesn't mean anything), and frequently the wiring harness that's been cut before and after the control unit, all at a very fair price. Also, for the race organizers, there's no difference between a retrofitted part and one that was supposedly factory-installed.
Translated on 09-10-2026, 22:40.
brezelmann01
Post27-04-2015, 17:04    Subject: A3 Sportback: Retrofit Tow Hitch Installation Quote
@ Matthias: And then you would have to wire the entire harness yourself? Or is it possible to get the individual wires from Audi/VW without the control unit?
Translated on 09-10-2026, 22:41.
Post27-04-2015, 19:48    Subject: A3 Sportback: Retrofit Tow Hitch Installation Quote
Yes, for example, it's quite easy to do. You can buy the connector and housing from VW and assemble it yourself. However, I admit it's a matter of personal taste.
brezelmann01
Post02-03-2016, 22:03    Subject: A3 Sportback: Retrofit Tow Hitch Installation Quote
Hello everyone,
I have a request (mainly for A3 Type 8P drivers), but also, for example, for Dieselmartin:
Could you please check if there is any voltage present at pin 9 relative to ground, or at pin 10 relative to ground, when the device is manufactured? In other words, is there a permanently powered/charging line installed from the factory?
Is it really true that terminal 30 on the trailer hitch will never be disconnected from the vehicle's power supply, even when the ignition is off? I find that hard to believe, since anyone can potentially access and tamper with it from the outside.
Thank you for your help!!
pretzelman01
Translated on 09-10-2026, 22:42.
dieselschrauber likes this.
Post03-03-2016, 0:21    Subject: A3 Sportback: Retrofit Tow Hitch Installation Quote
Is it absolutely certain that terminal 30 on the trailer hitch will never, ever be disconnected from the vehicle when the ignition is off? Is it absolutely certain that terminal 30 on the trailer hitch will never, ever be disconnected from the vehicle when the ignition is off?
Terminal 30 always means constant positive voltage!
Otherwise, it would be terminal 15, which is de-energized when the ignition is off.
Translated on 09-10-2026, 22:44.
Karma: +1102 / -0   Thank you, like it!
Post03-03-2016, 7:06    Subject: A3 Sportback: Retrofit Tow Hitch Installation Quote
The "terminal 30" connection on the trailer socket must be protected by a fuse. So, if someone were to tamper with it, a short circuit would result in a brief spark, and the fuse would blow.
This cable is useful for various purposes in a caravan, such as powering interior lights or an electric cooler. While it's possible to use an adapter to charge the towing vehicle's battery via the trailer socket, I believe that's more of a secondary benefit.
Translated on 09-10-2026, 22:45.
Post03-03-2016, 9:59    Subject: A3 Sportback: Retrofit Tow Hitch Installation Quote
brezelmann01 wrote:
A3 Type 8P (...)
Could you please check if there is voltage present at pin 9 relative to ground, or at pin 10 relative to ground, when connected to the
factory wiring? In other words, is there a constant positive/charging wire installed from the factory? }
According to the wiring diagrams for VW, there is no constant power or charging positive terminal installed (verified for model year 2011). However, surprisingly, pin 13 (ground for pin 9, constant power) is supposed to be connected.
That's all from the A3.
In the Passat 3C, it varied depending on the model year. The earlier models had the constant power supply switched on (I believe after 20 minutes) via a relay in the trailer hitch control unit. This was probably to prevent the battery from being drained. However, it was not ideal for those who use a caravan without an independent power system.
In later AHK-STG models (I believe starting in the second model year = 2007), the relay was eliminated and replaced with a jumper.
Greetings.
Guste.
Translated on 09-10-2026, 22:47.
brezelmann01
Post05-03-2016, 11:31    Subject: A3 Sportback: Retrofit Tow Hitch Installation Quote
Okay. The reason I'm asking is that I've decided to go with a Westfalia coupling. Unfortunately, the local junkyard didn't have an A3 with a clutch available. Apparently, they're too new and too rare to find.
According to the wiring diagram for the Audi, there is a constant positive connection, and it also runs through the trailer hitch control unit.
In the case of Westfalia (Hella STG), an optional wiring harness is required that connects directly to the battery, making it completely independent of the control unit. The corresponding pins are then free on the control unit for this purpose. All other pins are wired identically between the original equipment and the retrofit solution.
I therefore suspect that it might even be possible to wire the permanent positive connection as a standard feature. Perhaps Westfalia always includes a separate wire for it in retrofit situations, due to their modular design strategy.
Does anyone have VCDS evidence to prove that the software is different?
Translated on 09-10-2026, 22:49.
brezelmann01
Post06-03-2016, 13:33    Subject: A3 Sportback: Retrofit Tow Hitch Installation Quote
Here's the translation:
"As a follow-up question: Can I simply connect to the control unit using VCDS with the power, CAN-H, and CAN-L lines, or does it need to go through the gateway? This is just for a bench setup to read the software and hardware versions."
Translated on 09-10-2026, 22:50.
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Speed Control Retrofit Seat Ibiza / Polo Troubleshooting & Guides
No new posts A3 Sportback S-line suspension Transmission, Chassis, Body & Interior
No new posts A3 Sportback - Eliminating road noise Transmission, Chassis, Body & Interior
New posts Audi A3: Syncing Key Fob (8V 2016) On-Board Diagnostics (OBD)
No new posts Reset service interval for Audi A5 Sportback 2.0 Diesel On-Board Diagnostics (OBD)
