Which brake fluid should I use?
Thomas K
Post24-03-2003, 9:34    Subject: Which brake fluid should I use? Quote
I'm planning to put on my summer tires next week and replace the brake pads. And since I'm already doing that, I might as well change the brake fluid. But which type should I use (DOT 4 / 5.1, ...)? I couldn't find any information about this in the manual, and the sticker on the door says "only use genuine VW brake fluid"!
Does VW have its own brand of brake fluid?
Gruß Thomas
VW EOS 2,0 TSI; BWA; Bj. 06/2006
September 2020 ca. 180.000km
VW Bora Variant, AJM, Bj. 04/2001
04/2016 verkauft mit 378.000km
Sputnic
Post14-05-2003, 7:51    Subject: Brake fluid Quote
Okay, on my TDI's brake fluid reservoir, it only says to use DOT 4 brake fluid.
I guess that DOT 4 icon_lol.gif is going in there.
Thomas K
Post14-05-2003, 8:09    Subject: Subject: Brake fluid Quote
I've now seen it on the fuel tank and have followed the instructions accordingly. At that time, I only consulted the manual and the labels on the doors.
Gruß Thomas
This topic is locked, you cannot edit or reply. Oil stain under the car - transmission fluid or brake fluid? General Tips
No new posts DPF Retrofit: Should You Use VW 50700 Now? Diesel Engine Technology
No new posts Frozen Brake Fluid: Causes and Solutions. Transmission, Chassis, Body & Interior
No new posts Brake Fluid Change MJ07 to 08 Transmission, Chassis, Body & Interior
No new posts Bleed Brakes / Replace Brake Fluid Completely Transmission, Chassis, Body & Interior
