Timing belt pulley, KW brand, worn out - AFN engine
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Upload
Kiko
Avatar-Kiko
1996 Volkswagen Golf
Post20-05-2017, 13:30    Subject: Timing belt pulley, KW brand, worn out - AFN engine Quote
Photos of a damaged AFN timing pulley:
 Gegenhalter für Zahnriemenrad an der Kurbelwelle
 File size:  92.77 KB
 Viewed:  1610 times
 File size:  141.72 KB
 Viewed:  1503 times
 File size:  150.26 KB
 Viewed:  1500 times
 File size:  131.52 KB
 Viewed:  1297 times
 File size:  172.83 KB
 Viewed:  1425 times
 File size:  176.26 KB
 Viewed:  1370 times
 File size:  169.12 KB
 Viewed:  1370 times
 File size:  176.8 KB
 Viewed:  1647 times
 File size:  181.76 KB
 Viewed:  1366 times
 File size:  127.46 KB
 Viewed:  1289 times
 File size:  133.43 KB
 Viewed:  10759 times
 File size:  182.8 KB
 Viewed:  1439 times
Translated on 05-07-2026, 18:36.
Karma: +645 / -0   Thank you, like it!
Post20-05-2017, 17:22    Subject: Timing belt pulley, KW brand, worn out - AFN engine Quote
These are images that I've seen in real life before. In these cases, solutions might include using a milling machine, replacing the crankshaft, or installing a "rebuilt" engine.
"Some people have already secured the rear wheel using a dowel pin, and the really dedicated ones have even welded it in place."
I would try using the end mill.
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFB Engine Overview Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Worn Track Bar Bushings: Symptoms & Fix Transmission, Chassis, Body & Interior
No new posts VA Noises? Worn Ball Joints - Diagnose & Repair Transmission, Chassis, Body & Interior
No new posts Intake Manifold Bracket Broken (1Z, AHU, AFN, ALE) Diesel Engine Technology
No new posts Welding Timing Belt Pulley: How To & Tips Diesel Engine Technology
