TDI 8V Cylinder Head: 1.9 vs 2.0 Compatibility
ili
2004 Volkswagen T5
Post10-06-2016, 21:27    Subject: TDI 8V Cylinder Head: 1.9 vs 2.0 Compatibility Quote
Hello.
I'm new here and I already have a question about the cylinder head.
Is the cylinder head of a 1.9 TDI pump-injector engine, such as the ARL, compatible?
Is it the same cylinder head as the one used in the 2.0 8V TDI engine, for example, the BMM engine?
Thank you in advance icon_smile_thumb_up.gif.
Translated on 20-10-2026, 21:24.
dieselschrauber likes this.
Post10-06-2016, 23:25    Subject: TDI 8V Cylinder Head: 1.9 vs 2.0 Compatibility Quote
Yes, they are the same; it also says the same TN: 038 133 373 R on both. icon_wink.gif
Translated on 20-10-2026, 21:25.
ili
2004 Volkswagen T5
Post10-06-2016, 23:53    Subject: TDI 8V Cylinder Head: 1.9 vs 2.0 Compatibility Quote
"Thanks, I read somewhere in a forum that this number is just the casting number. That's why I wasn't sure if it would fit between the 2.0 and the 1.9 engines."
Translated on 20-10-2026, 21:26.
Post11-06-2016, 7:32    Subject: TDI 8V Cylinder Head: 1.9 vs 2.0 Compatibility Quote
"It's correct that the number 038 133 373 R, which is molded on the front right side, is not the actual part number for ordering; it's just an internal number for identification."
ili
2004 Volkswagen T5
Post11-06-2016, 9:47    Subject: TDI 8V Cylinder Head: 1.9 vs 2.0 Compatibility Quote
Thank you again.
The reason I asked is:
I bought a Golf 4 TDI GTI Exclusive, a 3-door model, and it has bent valves and a broken timing belt.
I have a cylinder head from a BMM engine lying around and I want to install it.
ILI
Translated on 20-10-2026, 21:27.
Post11-06-2016, 10:02    Subject: TDI 8V Cylinder Head: 1.9 vs 2.0 Compatibility Quote
You can use the head, but the PDE (Product Data Element) must be carried over from the old head. icon_wink.gif
ili
2004 Volkswagen T5
Post11-06-2016, 20:17    Subject: TDI 8V Cylinder Head: 1.9 vs 2.0 Compatibility Quote
Great!
Yes, I'll take the older PD elements.
Is the camshaft the same, or what?
"TDi GTIs are very rare, and that's also one of the reasons why I bought this one even with the damage."
Translated on 20-10-2026, 21:28.
Post11-06-2016, 20:59    Subject: TDI 8V Cylinder Head: 1.9 vs 2.0 Compatibility Quote
No, the camshaft is not the same.
Since the BMM engine has a closed particulate filter (DPF) system, a different camshaft profile is required for the PDE (pump-injector) system to enable post-injection when necessary.
Translated on 20-10-2026, 21:29.
ili
2004 Volkswagen T5
Post11-06-2016, 21:43    Subject: TDI 8V Cylinder Head: 1.9 vs 2.0 Compatibility Quote
Okay.
That means I have to use the old camshaft.
Thank you for the information.
No new posts Replacing injector nozzles in common rail injectors Troubleshooting & Guides
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts Timing Chain Wear: Inspection & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Injector Pump GRA Calibration Diesel Engine Technology
No new posts Pump-nozzle Diesel Engine Technology
No new posts Pump Nozzle Problem AXR - Common Issue? Diesel Engine Technology
No new posts Golf 3: Pump Düse Conversion Guide On-Board Diagnostics (OBD)
