Touran Steering Wheel Lock - Model 2004
chli1976
Post12-01-2016, 19:33    Subject: Touran Steering Wheel Lock - Model 2004 Quote
I'm currently in the process of replacing the steering lock on a Touran.
I removed the steering column so I could drill out the sheared screws.
Now I'm in the assembly process and wanted to insert the lock cylinder into the steering lock. Both are still disassembled. Since the pin of the lock cylinder and the corresponding part on the steering lock were not aligned, I used a screwdriver to turn the steering lock. Now it won't turn at all, and the locking bolt for the steering wheel lock can't be pressed in either. icon_question.gif
Is this some kind of anti-theft device? How can I reverse it?
VCDS
Translated on 08-09-2026, 11:59.
chli1976
Post12-01-2016, 22:15    Subject: Touran Steering Wheel Lock - Model 2004 Quote
I disassembled the new steering lock and removed the pin that was blocking it, and now it's working properly again, including the steering wheel lock.
It came apart easier than I expected.
VCDS
Translated on 08-09-2026, 12:00.
Post12-01-2016, 23:02    Subject: Touran Steering Wheel Lock - Model 2004 Quote
Thank you for the feedback.
Translated on 08-09-2026, 12:01.
No new posts VW Caddy Tailgate 2004-2013 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI BKD/AZV from 2004, Whistling/Squealing noise unde... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 / Audi A3 BKC Engine Failure: Won't Start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 steering lock in Golf 3 Transmission, Chassis, Body & Interior
No new posts Daytime running lights - 3BG, year 2004 On-Board Diagnostics (OBD)
No new posts VAG-COM Diagnostic Scan T5 Multivan, Year 2004 On-Board Diagnostics (OBD)
No new posts Passat 2004: Climatronic Repair & Troubleshooting Transmission, Chassis, Body & Interior
