Tow Hitch for VW Golf IV
Post12-05-2003, 17:58    Subject: Tow Hitch for VW Golf IV Quote
I have a question.
I managed to get an original tow hitch (detachable) from a damaged Golf (without any damage or deformation), and I'm now wondering which electrical kit I should buy. I was thinking of buying a standard one and simply connecting it with a warning light, since I hardly ever need to use the trailer.
If someone could tell me whether connecting the original wiring harness (or a replica) would also activate the trailer light indicator on the dashboard, and if it would be a plug-and-play solution, I would prefer that option.
Please help me with this.
Sure, no problem! Just provide the text you want me to translate.
Matthias.
Translated on 12-08-2026, 15:56.
Thomas K
Post13-05-2003, 11:16    Subject: Tow Hitch for VW Golf IV - Installation Guide Quote
matthiasTDI96 wrote:
I wanted to buy a regular one and simply connect it with some warning lights, since I hardly ever need the trailer.
Okay, so I bought a detachable tow hitch with the corresponding 13-pin electrical kit from Westfalia. The electrical kit is a plug-and-play solution; you simply plug it into the connectors on the rear lights on the left and right sides. Then, the cable is run through the vehicle's body to the outside, towards the tow hitch, and the individual wires are connected to the hitch. The turn signal indicator light is also activated, with no annoying beeping or other nonsense. So, I would recommend this electrical kit.
Gruß Thomas
VW EOS 2,0 TSI; BWA; Bj. 06/2006
September 2020 ca. 180.000km
VW Bora Variant, AJM, Bj. 04/2001
04/2016 verkauft mit 378.000km
Translated on 12-08-2026, 15:58.
Tagessuppe
Karma: +36 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post13-05-2003, 12:54    Subject: Tow Hitch for VW Golf IV Quote
That's correct. With companies like Westfalia, which are also original equipment manufacturers, everything is integrated into the system. However, if you have any questions, feel free to contact www.aukup.de.
They are professionals and offer the best prices.
Translated on 12-08-2026, 16:00.
Post13-05-2003, 13:22    Subject: Tow Hitch for VW Golf IV Quote
You're welcome.
I spoke with someone from kupplung.de who said that the turn signal light will never be activated unless everything is wired from the factory. I couldn't believe it. Now I know, and I'm going to get a Westfalia E wiring harness.
As I said, thank you!
Translated on 12-08-2026, 16:01.
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Towing Hitch Unlock: VW Golf 5 and Newer Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Crafter Tow Hitch Coding Electrical Systems, Vehicle Electronics, Multimedia
No new posts Backup fuse for trailer brake light. Electrical Systems, Vehicle Electronics, Multimedia
No new posts Trailer Hitch Registration with VAG-COM (Div. Steuergeräte) On-Board Diagnostics (OBD)
No new posts Retrofitting a tow hitch to an Audi A3 8V, production yea... Electrical Systems, Vehicle Electronics, Multimedia
