Blackfrosch Schrauber
13-04-2016, 20:22 Subject: Fuel Gauge Issues: Octavia III 2.0 TDI Range Problem |
Hello everyone,
"Like many others in the Octavia/Skoda forum, I am experiencing problems with the fuel level sensor or range indicator on my Octavia III 2.0 TDI."
In short:
The vehicle has a 50-liter fuel tank. If you drive it until the range indicator shows 0 km with an average fuel consumption of 4.5 liters, you can typically add approximately 42-43 liters to refill the tank. The combination instrument includes an adjustment channel for the fuel level sensor, but accessing it requires a login code, which I would like to know.
I once had some fun and filled the tank with 15 liters of fuel remaining, marking every 5 liters. (See log). The fuel gauge shows 5 liters less when the tank is empty, and at least 3 liters more when it's full.
Who has any ideas here? (besides testing the adaptation channel?)
| Description: |
| Log vom Tankgeber beim Tanken |
 Download |
| File name: |
LOG-18-361_tanken.CSV |
| File size: |
19.44 KB |
| Downloaded: |
548 times |
| Description: |
 Download |
| File name: |
Log-ERGDG59-TMBJJ7NE8G0178537-313km.txt |
| File size: |
13.42 KB |
| Downloaded: |
918 times |
Translated on 27-07-2026, 20:31.
bloesch Profi-Schrauber
Joined: 03/18/2005 Posts: 622 Karma: +16 / -0 Location: FL
dieselschrauber likes this. |
14-04-2016, 0:22 Subject: Fuel Gauge Issues: Octavia III 2.0 TDI Range Problem |
We've encountered this problem with one or two Octavias before. I seem to recall there's a technical bulletin (TPI) about it.
Conclusion: State of the art! Safety margins, avoiding unnecessary operation, etc.
Let me see if I can find anything; unfortunately, I have very little time during work hours...
Translated on 27-07-2026, 20:33.
Herbert Profi-Schrauber
14-04-2016, 8:17 Subject: Fuel Gauge Issues: Octavia III 2.0 TDI Range Problem |
VCDS directly displays the login for the instrument cluster (IC). For each individual customization option, VCDS usually also provides suggestions. Otherwise, you can find a lot of information online by searching for terms like "VCDS," "adjust fuel gauge," etc., although not necessarily specifically related to the Octavia.
Translated on 27-07-2026, 20:34.
14-04-2016, 9:51 Subject: Fuel Gauge Issues: Octavia III 2.0 TDI Range Problem |
If the login option were displayed directly, I wouldn't have asked such a silly question.
I'm aware that it's state-of-the-art according to Skoda, which is why I'm not even asking about that; instead, I'm taking the initiative myself. I also know what APKs are available, but I need the login credentials. That's why I've attached an Autoscan.
Hello.
Translated on 27-07-2026, 20:35.
Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
14-04-2016, 10:13 Subject: Fuel Gauge Issues: Octavia III 2.0 TDI Range Problem |
Try 13861.
Translated on 27-07-2026, 20:36.
Profile PM WWW Garage |
14-04-2016, 11:42 Subject: Fuel Gauge Issues: Octavia III 2.0 TDI Range Problem |
Thanks to you! I will test it as soon as I have access to the vehicle again. It might take until mid-next week.
Hello.
01-05-2016, 17:38 Subject: Fuel Gauge Issues: Octavia III 2.0 TDI Range Problem |
Access key not accepted  .
10-05-2016, 21:03 Subject: Fuel Gauge Issues: Octavia III 2.0 TDI Range Problem |
Are there any other ideas? This is really annoying with the vehicle. It drinks fuel like crazy, and you only have a 44-liter tank (when you run it completely empty).
Hello.
Translated on 27-07-2026, 20:37.
