Short circuit (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Post26-04-2016, 15:22    Subject: Short circuit Quote
The error codes P1213, P1214, P1215, P1216, P1217, P1218, P1219, and P1220 are triggered when a short circuit is detected in the injectors (fuel injectors) to the positive terminal (B+) for cylinder 1 (P1213), and so on, up to cylinder 8 (P1220).
Possible symptoms:
- MIL (Malfunction Indicator Lamp) light is illuminated on the instrument cluster.
- Poor engine performance.
Possible causes:
- The fuse for the relevant injector is defective.
- Faulty or damaged injector wiring.
- Injector failure.
- Engine control unit (injector control) defective.
Note: In Opel vehicles, error code P1220 can also indicate problems with the VP44 fuel injection pump!
Ratings - Short circuit
No new posts Error code 005399 / P1517 - Short circuit to ground Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM => Kurzschluss; Kraftstoffabschaltventil => mech. Diesel Engine Technology
No new posts _DEFINE0_ Error Code _DEFINE1_: Kurzschluss On-Board Diagnostics (OBD)
No new posts Terminal 58d - Short circuit to ground Electrical Systems, Vehicle Electronics, Multimedia
No new posts High-pressure generator (G65) 009 - Ground interruption/s... Transmission, Chassis, Body & Interior
