F B Guest
09-08-2016, 9:04 Subject: Volkswagen Golf 3, 1999, Immobilizer |
Hi.
Just a quick question.
How does the immobilizer system manifest itself in the above-mentioned vehicle when the wrong key is used or the signal is not recognized?
No spark when starting.
or
Starts and shuts off after 1 second?
Best regards, Frank.
09-08-2016, 10:00 Subject: Subject: Golf 3, 1999, Immobilizer |
F B wrote: | | Starts and turns off after 1 second? | That's exactly what it is.
Furthermore, one could potentially see an interfering WFS (Working Function Specification) through the diagnosis of the corresponding TCU (Telecommunication Control Unit).  MfG. Michael
Profile PM Garage |
F B Guest
09-08-2016, 16:07 Subject: Volkswagen Golf 3, 1999, Immobilizer |
Thank you.
Then it's not the immobilizer that's causing the problem with this car.
It's working again now, after a few failed attempts, as if nothing happened.
The error log is otherwise empty.
I therefore suspect the Hall sensor in the distributor.
He had announced his presence at another polo match in the same way...
Would an error appear in the VCDS log for that?
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
09-08-2016, 16:18 Subject: Volkswagen Golf 3, 1999, Immobilizer |
F B wrote: | ...
Would an error appear in the Vcds log file in that case? |
If the engine control unit detects the defective sensor: Yes.
Profile PM WWW Garage |
dieselschrauber likes this. |
09-08-2016, 16:32 Subject: Volkswagen Golf 3, 1999, Immobilizer |
"Hall sensor no signal" is generally logged as an error in older MSTG (Motor Steuergerät - Engine Control Unit) systems. This occurs when the ignition is on, but the engine is not running, because the Hall sensor cannot provide a signal in that state. The error can be cleared while the engine is running, but it will reappear after the next start.
"In newer engine control units (ECUs), this 'weakness' has been addressed. Consequently, errors are less likely to occur, even if there is a defect. This is because the ECU, lacking a second sensor, can struggle to distinguish between a situation where the engine is simply off and a situation where the Hall sensor is faulty, as both would result in a lack of signal." Here, manual troubleshooting is required; the error memory is not very helpful.  MfG. Michael
Profile PM Garage |
F B Guest
10-08-2016, 3:31 Subject: Volkswagen Golf 3, 1999, Immobilizer |
Yes, thank you, that's enough for my enlightenment.
Wonderful explanation.
Okay, let's just order a distributor, even if we're not entirely sure we need it.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1509 Karma: +644 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
10-08-2016, 11:09 Subject: Volkswagen Golf 3, 1999, Immobilizer |
"Another thing to check would be the ignition coil. We recently had a Passat 35i with an ABS engine that was having this problem – sometimes it would start, sometimes it wouldn't. We replaced the ignition coil, and everything was fine."
Back in the days when I used to drive gasoline cars, I always kept a can of gasoline in the trunk as a reserve. Sommer: A4 B5 Avant 2,5 TDI Quattro Facelift (AKN silber)
Profile PM Garage |
F B Guest
15-08-2016, 7:28 Subject: Solved |
It was the distributor, or rather, its Hall sensor.
It cost 25 euros at Schrotti's, and the thing is running again.
Thank you.
15-08-2016, 9:11 Subject: Volkswagen Golf 3, 1999, Immobilizer |
Thank you for the feedback!
